Page 3 of 3 FirstFirst 123
Results 51 to 65 of 65
Like Tree4Likes
Thread: My Crunch VE SSV Ute
  1. #51
    vrollin is offline Banned
    VE SSV Ute
    Sep 2007
    Almost complete, everything trimmed and dry and ready to go into the car tomorrow so I can work on the top panel and all will be complete until the wiring and subs arrive
    Weighs quite a bit and thats without the top panel and subs!
  2. #52
    VE SSV Ute
    Sep 2007
    In pieces;
    Dont ask why I trimmed it like this....not sure myself :S
    Behind the fascia
  3. #53
    VE SSV Ute
    Sep 2007
    First almost complete fitting into the car, and it fits! Well I always knew it would Heres some pics of it in the car and how it all comes apart;
    Bottom panel in place
    Heres how it sits in the trim madindust;
    Then the rest in...
    Hello little buddy!
    Just got a decent quote on a pair of 27v1s too, gunna put down an order
  4. #54
    VE SSV Ute
    Sep 2007
    Top panel in! Didnt quite go as well as I planned, would not go in in one piece so had to cut it into two, and then couldnt figure out why I had cut it the way I had? Either way it all fits. Im 95% happy with how its turned out, there are somethings I would do differently if I were to do it again but Im not gong down that road.
    Also there is an issue with getting the 27V1 subs, have been offered 27V2's, however I will have to run them together at a load of 4 ohm, where the 27V1's would run together with a load of 2 ohm so I could take full advantage of my amp. Other option is to run the 27V2's at a load of 1 ohm, but I just dont know if my amp will be stable to run it, manual doesnt state it is anywhere so Im not sure if I wanna risk it :S
  5. #55
    VE2 SV6 SPORTWAGON
    Feb 2006
    SA
    looks good, im assuming the wheel jack is being moved or staying where it is, its a pain in the arse to get out/in normally.
    The Mad Dutchman
  6. #56
    HUX 90's Avatar
    HUX 90 is offline POSION VE SS UTE
    09 VE SS UTE
    Mar 2011
  7. #57
    VE SSV Ute
    Sep 2007
    Quote Originally Posted by vicarious View Post
    Havnt played with the jack yet, the whole lot has to come out when the wiring odds and ends arrive anyway so if I cant get it out now then ill take it out then and work something out, even if I just strap it in the tray somehow, it doesnt really bother me
    Cheers again for the comments guys!
    3 week wait on the subs though oh well...
  8. #58
    VE SSV Ute
    Sep 2007
  9. #59
    VE SSV Ute
    Sep 2007
    Decided to make a nicer fascia for the mono block, never glassed before so it was a pretty steep learning curve and frustrations aside I really enjoyed the project and the outcome
    Turns out was probably a real bad choice of shape for a first timer with some odd lumps and bumps in the fleece, fixed it up with a bit of filler...
    Sneak peak at the amp fascia finished up, taken on iphone so excuse shitty pics...
    Also first photos ive taken with my subs in. Made a rookie error when covering the fascia, but all in all im pleased with my first attempt at such a thing
  10. #60
    VE SSV Ute
    Sep 2007
    Ok some shitty quality pics of it all together, Im really not happy with the top panel and its hideous join behind the drivers seat and a retarded decision to not continue the carpet over the top of the sub boxes has come back to bite me on the arse so I have to rectify that and think of how to do the top panels better. Will be the same design almost just need to think of a way to either do it in one piece or a way it can be put in with a fold in it with out a join in the carpet.....
    Can also just see in the pics where I had to make a cut in the carpet while trimming the amp fascia as I couldn't simply just lay the carpet over and push it down into it, if I knew it was going to have to happen I would have trimmed it by starting at the bottom and making the cut at the top where it points down and wouldnt have been as big. Not to sure how to fix that one....
  11. #61
    VE SV6 MY10 6SPD Manual
    Aug 2011
    FNQ
  12. #62
    Monaro CV8z
    May 2010
    Looks great mate.
    Some people say less talk more action, i say more torque less traction.
    Check Out My Rig Monaro CV8z
  13. #63
    HUX 90's Avatar
    09 VE SS UTE
    Mar 2011
    Loving the install. If you took the passenger seat out would the top pannel go in without having to be cut in half?
  14. #64
    VE SSV Ute
    Sep 2007
    Cheers hux, the prob isnt getting the panel in, it fits around everything fine, its fitting it in between the two bits of trim where it wedges into the sides just above the rear compartment lights Potentially I could make it one piece and put it in first before the boxes but my god it was a pain in the arse to get the right shape initially without having to pull boxes in and out to fit it in, thinking about it though it may be the only option....
    Other options running through my head are to mount an extinguisher on top on one side and a med kit on the other? Would cover the join partially while adding some extra safety to the car?
  15. #65
    Rufys is offline Banned
    VE Series II Calais Sportwagon
    Aug 2011
    LOOOOOOOOOOOOOOVE the sound system install. VERY nice setup indeed!
  1. 2007 SV6 Crunch Ute
    By strel in forum VE - WM
    Last Post: 13-09-2011, 01:28 PM
  2. Crunch crunch
    By newvsowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-07-2011, 02:24 PM
  3. [VIC] Ve ute lid crunch green
    By Kersh in forum Parts And Other Items For Sale
    Last Post: 02-01-2011, 09:46 PM
  4. Reverse and crunch!
    By madsav in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-03-2010, 06:18 PM
  5. fly wheel crunch
    Last Post: 28-07-2005, 03:28 PM
