ITEM: Its a fairly uncommon 5 litre V8 with 5 speed box, its an executive with Drivers side air bag and air conditioning (which works well). Theres a long story behind this car, but basically i rebuilt it literally from the ground up in June 2008 and have put approx 10,000 km's on it since.
YEAR: September 1996
SERIES: series one i think
BADGE: Executive
ENGINE: 5 litre V8
TRANSMISSION: 5 speed manual
COLOUR: Custom Bright Red acrylic with lotsa red pearl
EXTERIOR CONDITION: Good
INTERIOR CONDITION: Good but needs a new roof lining
TYRE CONDITION: 80% front - 90% rear
TYRE SIZE INCLUDING LOAD RATING: 235/55 - 16
ODOMETER: 143700
SERVICE HISTORY: Not recent, serviced by owner
REGO OF CAR: New South Wales
REGO TILL: June 2010
PLATES INCLUDED: Yes
RWC: I can organise one if you like, at your cost
PRICE: $5000.00 Negotiable
DELIVERY/PICK UP INFORMATION: I can deliver it to you (within reason) for the price of fuel, if car is paid for prior.
PAYMENT OPTIONS: Direct Deposit, Funds Transfer or Cash
CONTACT DETAILS: PM or email at bill_wilkin@hotmail.com, or pm for phone number
OTHER INFO: I have done the following to this thing,
New rings, bearings, gaskets and seals in the engine as thats all it needed, bores etc are fine, it uses no oil has more than enough power
Cleaned up the ports in the heads and shaved the heads, fitted new extractors and new 2.5" exhaust
Stripped, cleaned and fit new bearings to gearbox, new throw out bearing fitted.
Radiator cleaned, new hoses fitted
Injectors refurbished
Air con pump and power steer pump rebuilt - regassed etc
New Nolathane suspension bushes fitted, the only ones not replaced where the sway bar and rear links and i have those ready to go in.
New low king springs fitted
New front disc rotors and pads fitted
5 new King "Shimmy" mags fitted with new tyres.
Underbody cleaned and re painted with sound deadener inside and out
New carpets fitted
repainted in my own special bright red acrylic mix with plenty of red pearl and 6 layers of clear, theres about 1.5 litres left over for touchups
New windscreen fitted
Other stuff
Fitted with a standard beam rear axle with an LSD centre
JVC casette/cd/radio fitted with 4 JVC speakers and CD changer in the boot
Comes with a Hayman Reece tow bar and ball, which needs fitting, car already has 7 pin trailer plug wired in
Comes with a SS Commodore rear spoiler, if you want to fit that.
Registration to June 2010
it has a dash mat!
Spares
2 sets of rear doors in good condition
1 front passenger door in good condition
1 set of front mudguards in reasonable condition (minor repairs needed on one)
1 spare standard wheel with very good tyre
set of front headlights and blinkers
spare new distributor
spare new sparkplug leads
spare fuel cap
spare incomplete engine gasket set
spare body wiring harness (good for spare connectors etc
spare airconditioner / heater unit suitable for spares (in case the heater core leaks etc etc)
set of spare back side quarter windows
various trim parts
The Bad Stuff
The gearbox has a whine in reverse, a mechanic has told me not to worry about it until it needs a new clutch, then replace the reverse idler gear. Typically when i had it apart everything was fine, its just started acting up now.
It needs a new roof lining
Since lowering it i havn't been happy with the wheel alignment and we don't have a suspension specialist out here in the bush. I'd take it too Pedders or someone who knows this stuff and get a proper alignment done. It has a standard spec alignment at present.
I havn't finished replacing all the suspension bushes. I didn't do the sway bar rubbers and the lower rear suspension bushes as they are still ok, but they should be done regardless due to the age of the vehicle, so i'm supplying Nolathane bushes with the car to do this, if you're mechanically minded its an easy job
I painted the car myself, and while i'm not a professional it's turned out well, just not professional though. It needs a proper polish.
The front and rear bumpers are a bit rough. I was going to fit a body kit but havn't got to it.
It needs a new air con switch, its stuck on and switch broke.
It needs a new front ash tray
PICTURES:
Forgot to mention - I may be interested in doing a trade if you have something interesting, particularly motorcycles.
interested in KTMs
As a matter of fact yes, i'm into dirt bikes,i used to run a KTM 660 Rallyeand have just finished building a Ducati 900 Monster enduro bike
hmm like your style, my brother has a 03 or 05 KTM 250 exc (i sold it to him lol) and i know he is chasing a cheap car maybe trade this with a cash adjustment your way, the bike has just been rebuilt i have spares ect ect ill talk to him about it tommorow if your interested......
on the other foot i ride a husaberg 650 Fe last release of the 650 keeps up with my mates R6 till i top out love it
Yeah the Husa with the new motor is crazy. That KTM, is it registerable? If it can be regoed then sure let him know i may be interested.
OD
Guess that didn't work out, so its a big old Bump! and i've attached a short cut to the build thread Olddogs VS 5.0 litre Exec
SOLD Bit of a shame really, i put a ton of work into it, anyway, its off to its new home near Melbourne.
