Results 1 to 4 of 4
Thread: 5 speed cold idle question
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Default 5 speed cold idle question
    Got an issue with my bros 5speed atm, its wont idle when its cold..
    any ideas??? ill look in my book but any help would be sweet
    Cheers!!!
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    the most common problem to cause this is an air leak between the afm and throttle body when the engine warms up the ducting can expand sealing the leak, other causes are air regulator, fuel supply and ignition coil, resistor, leads and plugs, aac valve and idle air controller valve.
    also a blocked dirty air filter.
    Nobody wants to play with me
    Goon's Avatar
    Feb 2006
    GC. QLD
    Quote Originally Posted by jatsvl View Post
    Cheers bro ill get my bro to go over them tonight
    Goon's Avatar
    Feb 2006
    GC. QLD
    I fixed it, was just an air leak after the afm, my bro forced the air filter in on the swap lol, plus i erased the ecu memory all good now!! woo!!
  1. 5lt camy idle when cold
    By IhateRICE! in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-03-2009, 10:09 PM
  2. VP refuses to idle when cold
    By adamu in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-06-2008, 12:22 AM
  3. Idle up when cold
    By cohn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-01-2007, 08:18 PM
  4. Rough Lumpy IDLE When Cold
    By phill025 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-12-2006, 12:36 PM
  5. 91 VN Rough Idle When Cold
    By tep_aus in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-02-2006, 07:27 PM
