Results 1 to 22 of 22
Thread: so i swapped plenum's over and no she wont run
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Default so i swapped plenum's over and no she wont run
    First of all i didnt get a chance to depressure the fuel system, as i was putting in a new**bleed bolt" when i refilling my cooling system** on the old plenum and i overtighten it resulting in a split with a nice hole..silly fatgiue got to me with the socket wrech
    i drained the cooling system now ive changed plenum's over .....but i havent changed the "auxillary air control valve" or the ''throttle valve switch thing'' yet.. and refilled the cooling system
    the top half of the plenum is from a r31 skyline... i havent used the bottom half with the injectors and coil "As the coil has a different connection"
    my issue : she fires and runs for 1 second even a micro seconds and turns off..
    the throttle cable i had a pain in the ass getting back on casue the new throttle on the plenum is tighter then the last so i may have flooded it?
    im going to run an ecu test soon
    should i invest in a torque wrench??? to redo the plenum bolts? my book has alot of torq settings...the bolts feel tight enough atm.
    Cheers.
    ps. all hoses are connected!
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    being fuel injected u have not flooded it you cant :P.
    i would say possibly something with the vacuum lines, but then again it should not run at all.
    I changed my plenum over (Caus i cleaned it + throttlebody) and ran so much better.
    how about the TPS sensor did u change/Adjust that?
    Goon's Avatar
    Feb 2006
    GC. QLD
    Quote Originally Posted by detox_nath83 View Post
    TPS Sensor? another word for it? or whats it stand for? throttle postion sensor?
    Goon's Avatar
    Feb 2006
    GC. QLD
    i found my problem the auxillary air control valve area is blocked to the sht house, ill unblock it and things should be sweet!! i hope
    Goon's Avatar
    Feb 2006
    GC. QLD
    Atm i have to rev it to get it to fire up but it backfires, ive taken the plenum off again and im going to further insect it for blocks...i know its not my afm or cas casue it all ran before i swapped plenums.. im going to reset the ecu to to see if it helps, ive swapped every part over to the newer plenum...
    any think if its not tight enough it may be casuing this? the joins between the plenum
    Goon's Avatar
    Feb 2006
    GC. QLD
    Im thinking she maybe out of fuel as it reads on i little bit over E which would explain the backfiing.. ive hooked it back up im going to get some juice before i try it again
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    u should never pump the throttle to start fuel injected cars. the backfire can damage the AFM very easily blows out the hot wire(hall Sensor) clean that AAC Valve and make sure the small pin moves very freely is the throttle body butterfly valve clean and clear not crap restricting airflow/ blocking the small pin hole at the base of the flap for idle. might pay to take it off unscrew the valve and clean it all up. Thats what i did and ran beautifully
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Could be a possibility i didnt replace a gasket there (between the 2 halfs of the intake)and i have not had a problem
    Quote Originally Posted by Goon View Post
    Goon's Avatar
    Feb 2006
    GC. QLD
    cheers mate , its all clean im going to get some juice then firing her up
    Goon's Avatar
    Feb 2006
    GC. QLD
    added juice and it was nice to hear her running tonight but just soudning like a pig before she cuts out.... i suspect its my thorttle cable or something to do with the throttle im going to inspect it further in the daylight and do some adjustments and hit my book.
    Goon's Avatar
    Feb 2006
    GC. QLD
    LOL!!! just went to grab my book from the shed to have a quick read before i hit the hay and noticed this crap on the ground from my exhaust when i fired her up, i know its not a substance from my exhaust its NEW! possible the extractors there they same colour but lol !!! looks like rusted water but tis dry so i couldnt tell...
    Well i hope i sort this out soon.
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    I'd say u got water getting into ur bores? Double check everything which has water going through it....that's prolly why it ain't running either. And keep an eye on ya oil level and make sure it doesn't start gong milky or it means ur getting water in the oil....which isn't good.
    Goon's Avatar
    Feb 2006
    GC. QLD
    Quote Originally Posted by DANNY8 View Post
    nah the water has dropped.. and the oil is as a good as gold.
    Goon's Avatar
    Feb 2006
    GC. QLD
    Woooohoooo shes running again yessssss!!!!! A few new lines, thorttle cable and the tps swp over.. Fk i hate skyline parts.
  15. #15
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    i would have said its not the throttle cable bud. i would say the TPS sensor.
    As well as the rusted water. could either condensation build up in exhaust.
    another reason could be Cracked head causing coolant to leak into the cylinders like danny8 said.
    Keep an eye on your coolant level and milkiness, oil and water will go milky.
    Well done on getting her going to bud
  16. #16
    Goon's Avatar
    Feb 2006
    GC. QLD
    anybody know if the skyline plenums are the same size as the holden ones??? it has a different part number printed on it..
  17. #17
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
  18. #18
    Goon's Avatar
    Feb 2006
    GC. QLD
    same motor i would suggest its the same.
    have not looked though :P
    whats up with your one???
    just curioisty mate
  19. #19
    Goon's Avatar
    Feb 2006
    GC. QLD
    95 dollars later and shes running again back to normal, no issue, no backfiring, no need to use the pedal.. ahahahahha wooooooooooooooooooooooooooooo!!!!
  20. #20
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
  21. #21
    social's Avatar
    social is offline Commodore Enthusiast
    2006 6.0L VZ Thunder
    Nov 2008
    South Aus
    nice work mate gotta love it when it finnaly works out...
    Quote Originally Posted by Shooter03 View Post
    Washed it and now the wife's gonna take it out and get it dirty.
    Quote Originally Posted by QldKev View Post
    You are talking about the car?
  22. #22
    Goon's Avatar
    Feb 2006
    GC. QLD
    so what it end up being dude?
    dunno really i just had patience and took my time with it... replaced the gasket, lines, throttle cable and the hose clamps and adjusted the "what i thought was the tps" did it all just to make sure i didnt miss a thing... oh and blowout the plenum with the good old air comprosser plus cleaned it up even more.
  1. help with a vn that wont run please
    By 078commyboy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-01-2008, 04:34 PM
  2. V6 wont rev...
    By 10000_fists in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-10-2007, 05:16 PM
  3. dizzy heads cant be swapped
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-10-2006, 06:33 PM
  4. Has anybody ever swapped stock springs with SS springs?
    By vzuterus in forum General Discussion
    Last Post: 01-06-2006, 02:20 AM
