Results 1 to 3 of 3
Thread: RB30 Cam Advance 1 notch?
    VL vacationer 3.0l
    May 2009
    Christchurch, NZ
    Default RB30 Cam Advance 1 notch?
    We are sending our 3.0L VL for it's first tune for 12 yrs, cause it's running rough when cold, and just getting grotty.
    My question is, is it really worth it advancing the cam 1 notch on the wheel. It is family transport, mostly short trips around the city, we are interested in smooth running, driveability, and economy.
    If I advance the cam, is there any problem getting the distributor to the re-timed position? I heard that it runs out of slot to get back to 15deg BTDC.
    Is there any benefit to running slightly advanced ignition timimg?
    thanks for any help.
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    mate i would suggest clean inner throttlebody butterfly and housing, plenum and intake runners.(Or just plenum if u dont want to pull it apart too far.
    New spark plugs/ leads/dizzy cup and clean all electrical plugs as well as light sand of the dizzy rotor. Oil Change with oil 20W50 viscosity(Penrite/CastrolGTX2) and some good tectaloy coolant 100 gold.
    I would not touch the cam timing.
    Just use a timing light and set your timing between 15-17 where ever your car likes it with responsive power down low as well as top end.
    get a performace panel air filter(K&N) clean the AAC valve on plenum as well.
    Check all Vacuum hoses for leaks and cracks as well as intake piping for air leaks. put through some injector cleaner. New fuel filter and you should be sweet.
    Should run like new being responsive when you need it and run smooth.
    Should be able to balance a 50c Piece on it side on the rocker cover(Near oil Cap)
    Goodluck
    VL vacationer 3.0l
    May 2009
    Christchurch, NZ
    thanks Detox
    I'm on it.
  1. skyline r31 rb30 coil on vl rb30 motor
    By Goon in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-04-2009, 10:30 PM
  2. Pacemaker Vs Advance
    By Tommi5.0 in forum V8 Development and Modification
    Last Post: 01-02-2008, 04:41 PM
  3. ADVANCE extractors
    By lasco in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-03-2007, 11:44 AM
  4. advance headers
    By webwombat in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-12-2006, 09:33 PM
  5. Top notch panel beaters in VIC...
    By VL Soldier in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-08-2005, 08:37 PM
