Results 1 to 9 of 9
Thread: engine rebuild questions
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Default engine rebuild questions
    so i got an offer for the ACL standard rebuild kit and a turbo kit which is atlittle more in cost but im thinking if u use a decomp plate with the stadard kit for my turbo? or would the turbo kit plus the decomp plate be a better choice???
    alongside with a 3 core radiator plus gktech intercooler
    VT V6 Injectors and upgraded rail.. would i have to get the standard ecu reprogramed to suit the injectors?
    as i guess a turbo ecu would have to be the same?
    but i have nistune in mine for another upgrade to the ecu to go with the standard ecu.. so either way i would have to get it tuned to suit the injectors? or just plug and play?
    for fuel pump wise, any parts i should add to my list???
    silly question...does a diff type have anything to do with the way the ecu should be setup??
    Cheeers ALLLL
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    Quote Originally Posted by Goon View Post
    Either the standard kit with a decomp plate or just the vlt rebuild mate, I'd strongly recommend avoiding the decomp plate. I've never liked them but some people will swear by them.
    Doubting these will work without a different ECU, stick to standard VLT injectors.
    Same as? If you're running the vlt setup you'll need the vlt ecu, or an aftermarket ecu.
    don't think they'd work straight up though.
    Lots of random parts, VLT fuel pump would be fine, or maybe just a Bosche internal pump that flows decent numbers, you wouldn't really need much if you're just sticking with standard. Brakes? Gearbox?
    No difference at all.
    Goon's Avatar
    Feb 2006
    GC. QLD
    Quote Originally Posted by Bax View Post
    Thanks for answering my question mate, yeah i get teh turbo injectors fur sure, vt's only cost my 20 bucks years ago, just something i had in my shed
    I'll chase down the turbo rebuild kit, sounds like the way to go
    Standard box and brakes for now, thought im upgrading the brakes in he future
    Bax
    Nothing
    Jan 2004
    QLD
    Auto box or manual box? I've been using the manual box behind my engine now for a year - to be honest it's lasted better then I expected. I've been quite vigerous with my driving from time to time and although it hasn't copped any crazy gear changes and the like, it still does get a hammering. Apart from it sounding like it's about to explode and huge amounts of bearing noise, hard to get into gears sometimes, it's actually survived pretty well.
    The auto should be okay as well and you can always get a transmission cooler which will give it a bit more life.
    I had drums/ with non turbo brakes on my old maroon car, to be honest I didn't notice the difference much, but the better brakes definitely won't go astray in any case.
    The way I see it as far as the rebuild goes, if you're forking out money for any type of rebuild, you may as well at the bare minimum get a vlt standard build.
    My original plan was to just convert the engine to turbo, bolt the bits on and use a high comp setup, only to have a second engine getting built that was serious if I was to ever change over to something really good.
    vl calais
    May 2009
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    Quote Originally Posted by slugsh6 View Post
    the na turbo ecu will run the turbo untill around 7psi boost then cut
    na turbo ecu wow thats a new comp, how do they work?? flick a switch for turbo mode and flick it again for na
    na ecu will run past 7psi but the injector cycle wil be too lean for safely running the motor
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Goon's Avatar
    Feb 2006
    GC. QLD
    I'm just going to run it at 7psi until i upgrade the injectors, probley get a turbo ecu or something "nistune" at the sametime.
    Oct 2005
    problem is if your wastegate is leaking it can allow the boost to spike higher then what its set at
    so you might hit 10psi + for a few seconds and it eventually come back down
    something you want to be careful with as you gamberling on the fact it will hold 7psi and no go up where it will lean out
    just wait that little longer before you put the turbo on and get the injectors and a comp
    cheaper then rebuilding a motor or less effort then swapping the engines
    the factory manifold bolts are fun to get on...........not
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    Goon's Avatar
    Feb 2006
    GC. QLD
    Quote Originally Posted by VL Berlina 5speed View Post
    Thanks for the tips mate, ill ride with that plan
  1. VN series 1 questions for rebuild
    By needwork2-4fillhabbit in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-01-2009, 02:10 PM
  2. Engine Rebuild
    By Wasa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-04-2007, 01:22 PM
  3. Diff Rebuild Questions
    By Dezza in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2007, 12:39 PM
  4. Engine Rebuild
    By Griff_Sle in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-02-2006, 02:58 PM
  5. Vn V6 Engine Top-end Rebuild
    By jules in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-01-2004, 08:20 AM
