Hi Guys, I am trying to get my Vl to run as it has been sitting for a long time with stale fuel in it, I can get it to start, and Idle althouhg roughly, but if you accellerate past 2000 rpm it stalls, I ahve cleaned out the fuel tank, put clean fuel in, replaced the hoses for the fuel reservoir, any uggestions as to what would be causing this to happen and how the hell am I going to rectify this problem?
Thanks
blocked fuel filter. dirty injectors, loose battery terminal
SIR LS1
the two ton go kart
check your exhaust isnt blocked 2 aye, i had that hapen 2 me
100% Its The Air Flow Meter If its Stuffed The Car Will rev to 2000rpms Then Start Surging There Cheap on Ebay !
had same problem with mine and was just a wire to the airflow not connecting so try wriggling the wires around yours first, saves buyin a new one if its that
