Hello.
I'm getting a VL commodore sedan rolling shell which comes with the auto V6 but isn't in the car and am hoping to put a V8 out of either a VR/VS in it with the 5 speed box.
I just wanted to know how difficult/expensive this would be or is it considerably easy/in-expensive.
Your help would be greatly appreciated.
Cheers![]()
vl/vs use same k frame ( crossmember () and front suspension. may have to change strut tops... all bolts in fairly easy
SIR LS1
the two ton go kart
buy a smashed 5L if you have the space too other wise you are crazy, you should be able to pick up a nice 5L anything from auctions for under $2500
from what i remember vl/vn/vp/vr were pretty much straightfoward bolt ups, but the vs needed a little bit of modification to fit into the vl front end...
nothing a little bit of patience and a few mates can't overcome.
good luck with the conversion mate
