just a quick question, when in full lock from a standing start when i accellerate (parking etc), my steering shudders violently.
i am thinking lower balljoints need attn. am i on the right track?
This is good site to watch.I found it informative as I have been researching a lot lately on such matters such as you talk about.
when moving along if you full lock what does it do? same thing?
yeah a little bit, but i try not to have it in full lock at higher speeds. i quess when i'm doing 3 point turns and stuff.
so no one else has ever had this problem?
you should check all of the front suspension ball joints, strut tops, swaybar bushes etc... and another cause low power steering pressure/fluid, worn belt, loose steering rack, worn or loose wheel bearings and bold or uneven front tyres.![]()
Nobody wants to play with me
cheers mate
