Everytime put a new 7.5amp fuse in for the dash lights number 5 i think it is, keeps blowing. I turn the lights off put in the new fuse turn the lights back on and the fuse is dead i changed it 4 times and the same thing happens. any ideas anyone??
shorting out somewhere
i had a simular problem with mine 2 years ago which i found two probs
the two cables on the sliders for the ac had warn the cables down and shorted out on each other
also the dash dimmer switch, this can arc sometimes melt the wiring so it blows
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
fuse #4 is parkers and dash, check your park light relay and that your tail/headlights are not full of water.
Nobody wants to play with me
did u just install the stereo? if so id say u hooked the park lite wire up to ur earth on the stereo. if not have u got a trailer socket.
All fixed now the dash lights was the cause auto electric fixed it up.
