Results 1 to 4 of 4
Thread: Timing Belt snapped at 38km have I stuffed it?
    vl berlina
    Aug 2005
    Red face Timing Belt snapped at 38km have I stuffed it?
    This evening after an already bad day, i was driving home behing an old blue hair, went to change gears then nothing. No power no nothing. When I got home and pulled a few bits off the engine, lo and behold a snapped timing belt. But no major noises came out of the motor when she cut power.
    What do you reckon I'v busted. One mate reckons I should pull the head off before changing timing belt and check valve and piston damage. The thought of which is slightly daunting, cause it's been a while since I'v done anything like that.
    What's your opinion?
    VX Executive S2
    Jun 2009
    jus go and buy a timing belt install and go from there. much cheaper than pulling head off cause if the head is ok u wont have to buy a new gasket wen its time to put it back together.. id say engine is ok if its a free spining engine. not sure if its a free spining engine. should do a search on it
    vl berlina wagon 6cyl
    Jul 2005
    are you sure its snapped? from what Ive heard its interferrence and their should have been noises
    look at camshaft while starter is operated and see if cam moves or not
    keep old belt as evidence if it did snap
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    did you do any other work while your were doing your cambelt? I have seen cams seize in these things causing it to snap or shred teeth off
    Gas, Ass or Grass nobody rides for free
    Quote Originally Posted by vsv8berlinawag View Post
    You tell him (coz you are right)
  1. vl timing belt?
    By starfire vc in forum VL Holden Commodore (1986 - 1988)
    Last Post: 22-06-2010, 09:06 AM
  2. how to timing belt on 2000 mdl barina?
    By mattyr82 in forum General
    Last Post: 24-02-2009, 04:49 PM
  3. timing belt!!!
    By ImAHoon! in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-12-2008, 11:27 AM
  4. It all started with a broken timing belt
    By Simion in forum VL Holden Commodore (1986 - 1988)
    Last Post: 11-12-2006, 12:25 PM
  5. New Timing Belt Installation
    By Dan355 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 20-11-2006, 12:11 PM
