Results 1 to 8 of 8
Thread: ecu help !!!
    gazza101 is offline rb 30 det
    1987 vl berlina & r32 skyline
    Jun 2009
    Hamilton nz
    Default ecu help !!!
    hey i have a 1987 3 litre vl berlina it has been tampered with a bit and i cant get it to start . i have put new injectors spark plugs and fuel pump but its still not working . theres spark there and gas to fuel rail but beyond there is a mystery .. it also has a 2em ecu in it ... is this wrong becose most ive seen have a 3em ecu ... any info or help wuld be very much appreciated . thanks
    ps how can i tell if its a 3 litre or 2 ?
    was told its a 3
    VT spac super6
    Nov 2008
    Riverton sa
    VL Wgn & VL Sdn
    May 2009
    The Shed...W.A.
    Would definatly get same ECU as standard.
    An has the dizzy bin out ?
    Also check ur imobilizer(if fitted).
    Regards oldboi
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    Hamilton NZ?
    would most likely be a 2lt RB20.
    on the options plate below the vin plate the engine code will be LC6 denotes a 2lt this won't help if the engine has been changed thou.
    the 2 on the ecu would be a good indicator to because all the vls I have owned all have a 3 on the ecu.
    Nobody wants to play with me
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    2EM is RB20 manual ECU
    Jun 2009
    Hamilton nz
    thanks for all your guys help . it dose infact say lc6 and am pretty sure its a rb20 . thanks
    will try a new ecu and see wat hapens . again thanks
    vl
    Jul 2009
    it sound like your dizzy is out, my vl did the same thing like your is doing, if you want email me at
    batmanonfire@msn.com and I will give you my mobile number and then you can call and I will talk you through it. If you havent fixed the problem. If you email me put "about VL" as the subject
    1988 VL Commodore (Wagon)
    Jul 2009
    Quote Originally Posted by gazza101 View Post
    I have just diagnosed my own VL which had the same problem, it was a faulty fuel pump.
    I removed the pump and tested it with a battery charger (12 Volt) in a bucket of water and it is definitely cactus.
    I would suggest you investigate the fuel pump too as I had spark from the dizzy and at the plugs as well as fuel at the rail like you. The problem seems to be that pump was priming but it didn't deliver enough fuel to start the engine.
    PS if you are having problems with the ECU disco the battery overnight and the ECU should reset.
