+ Reply to Thread
Results 1 to 13 of 13
Thread: vl not pumping oil
    vl commodore
    Jun 2009
    Default vl not pumping oil
    hey guys can any 1 help me out i have a vl that i just turbsd and just recently changed the head due to exhust threads were stuffed so i got another head and gasket put it back together and iam not getting oil to my oil feed line or my oil gauge but it seems that iam getting oil to the head verry slowly any ideas ive tried to pump oil back down my gauge into the block and pumped oil down my feed line asuming that my oil pump has an air pocket in it can any 1 help many thanks lanca
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver detox_nath83 Executive
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    how frequent have your oil changes been.
    old oil will get gummy and make bad deposits blocking oil galleys etc. a good indication would be look at your old head under the rocker cover. is it really gummy with grit etc. or is it lightly colored with oil stains etc. this would kinda let you know how it is through the rest of the engine. how did you feed your turbo from the grommet on the exhaust side if the block(series 2 Rb30) or a t piece from oil sender under intake plenum? chances are if your gauge aint working and your getting no feed it could be blocked oil gallery on sender side.
    Good luck bud
    c pic for reference, very dirty head not many oil changes
    Attached Thumbnails Attached Thumbnails vl  not pumping oil-september-07169.jpg
    VT spac super6
    Nov 2008
    Riverton sa
    Quote Originally Posted by detox_nath83 View Post
    Good luck bud
    holy cr*p!!!
    iv never seen a vl head that bad!
    iv seen in the 3 sofar and all spotless
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    vl commodore
    Jun 2009
    hay nath thanks 4 the reply head wasnt bad i just took it of due to the exhaust threads were stuffed and couldnt do up my top mount headers enought so swaped head now the oil prob ? blocks all good recently been rebulit so iam not shaw maybe i might have 2 prime the pump ? my feed line is coming out of the feed hole on the passangers side of the block an thats not blocked ?i think its seris 1 rb 30 just a stockey but still runs 17 18 psi no probs freak motor illd say
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    hmm weird... possibly the oil pump impeller has shit itself... i feel its quite unlikely though....you should not have to prime the oil pump.
    I know this is stupid but hows your oil level. rb30s take approx 4.7 litres and are known to hold a bit top end
    whats the condition of the head u put on it. possibly oil galley blocks?? or not possible ??
    if the rb30 block has the bung on the passanger side for oil feed and a larger one under it above sump for return as well as a water feed bung for turbo. then its a series 2 block.
    these were not featured on series 1 block therefore you had to drill into a galley or t-piece off the oil sender.
    vl commodore
    Jun 2009
    head was sweet that i put on made shaw of it and the block dose have the drain line under the feed line and the water at the back end but i dont need the water line its a after market turbs just oil feed had another go at it but it still not pumping oil so i think its the pick up so looks like iam takeing the sump off
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher VL Berlina 5speed Monaro VL Berlina 5speed Monaro
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    so your getting a trickle through your oil feed hole?
    remove your oil sensor just behind the oil filter and see if anything pumps out
    your blocks oil gallery runs along the drivers side, you then have a shaft running between piston 3 and 4 to your oil feed (this runs in line with the oil filter)
    if you are not getting much out of both then your problem is at the oil pump or a block in the gallery from the pump to the main oil gallery
    you say you have been running the engine with 18+ psi is the oil pump the turbo or na one? might be pushing the limits of possible na one and its gave up just before you decide to change heads
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    vl commodore
    Jun 2009
    yeah thanks man thats what i was thinking shes stuffed its just a stock vl motor lol just an experemnt ive got a vt cluby just playing around with the vl but it got me stuffed i expected it to stuff up but it was going sweet just had to sort out the external waste gate not shaw how they work i do but dont its a top mount setup t4 lol then i took the head off now no oil presure stumped and ive just got a gauge comeing out the sender side into the dash i no on the vn v6 you have to prime the oil pump so gather i try the pick up or change the motor i got another 1 there but this block looks better
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    basically a vacuum line is fed from compressor side of turbo to wastegate side port. once the psi in the vac line/intake gets up to wastegate setting say 12psi it opens wastegate so exhaust pressure is purged b4 the turbo and keeps the psi at a limit. then u can have a manual boost controller inline b/w compressor and wastegate to adjust the pressure in the vac line(but manual boost controller will not adjust below the spring setting in the wastegate) so if its a 12 psi spring in wastegate the manual boost controoler will not work under 12 psi only over it (there is your wastegate lesson :P)
    Catchin' what im throwin'???
    vl commodore
    Jun 2009
    yeah thanks man thats what i thought just wasnt shaw theres a few was to hook em up thats the way i got it setup now you can also hook boost to both ports witch makes the gate stay shut a lil longer due to greater presure so ive heard
    Goon's Avatar
    Goon is offline VY COMMODORE BABY! Goon Executive
    2004 VY COMMODORE S2/V6. SKYLINE R33 GTR TURBO
    Feb 2006
    GC
    Good luck bud
    dam if my head looked like that id cry a river hahahaha!!
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    vl commodore
    Jun 2009
    hey fellas found out my prob with my oil prob 4 any 1 thats havn the same prob and just carnt find the prob i had tried everythink and it ended up being my oil pump houseing at the front under so mutch pressure the oil pump sucked in the caseing a pice the size of a 1 cent peice but did not leak oil just was sucking air havnt pulled the oil pump apart yet just changed the block
+ Reply to Thread
  1. Not pumping fuel
    By leslloyd in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-12-2008, 02:57 PM
