Results 1 to 15 of 15
Thread: Air Filter Box Cover + POD
    VL Executive
    Feb 2009
    Craigmore SA
    Default Air Filter Box Cover + POD
    Hey guys
    Firstly i know there is a lot of threads on here related to pods and CAI but couldnt find exactly what i was looking for
    I am probably going to follow coastvls guide on CAI for my vl however the noob who had my car before me removed the top half of the air filter box and whacked a pod filter in.
    My question is.... where can i buy just the top half of the air filter box and also will it fit the pod filter in ok.
    Also my knowledge from reading other posts makes me think that a pod filter and a cold air intake might suck too much air and as a result will choke the engine and/or cause the car to use more fuel.
    I know that if this is the case i should buy a K&N panel filter, but dont have heaps of cash at the moment so will a pod filter (providing it fits) be fine for the short term....or as long as possible??
    Thanks heaps
    P.S. Car is on gas if this makes a difference at all?? :S
    86 vl berlina
    Mar 2009
    vic, in the shed
    Mate best bet is to save for a k&n panel filter, if u already have a pod try an see if it fits right but make sure its only for a short time an get a panel filter asap.
    VL Executive
    Feb 2009
    Craigmore SA
    thanks i thought that might be the case.
    i would obviously still need to get the top half of it wouldnt i?
    detox_nath83's Avatar
    detox_nath83 is online now Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    more air the better bud. your ecu and afm will work together to compensate for air flow(Think of a turbo airflow) it wont choke the engine run a heap better.
    i would suggest as above stated to get a K&N Panel filter and service it regulary as in clean and reoil filter.(depending where u live.... dusty terrains etc)...
    i have a thread on here a few years back about my CAI install jobby with pics.
    if u dont have the top half of the airbox you will need it as the AFM bolts to it. unless you do have the pod. my opinion Pods suck warm air from engine bay so i would recommend doing the CAI as well.
    some states allow pods only if they are boxed. check SA laws
    VL Executive
    Feb 2009
    Craigmore SA
    thanks nath
    I went to u-pull-it and grabbed the top half of the airbox today for $8 ....bargain... another wreckers wanted $25
    Had a bit of trouble putting it in though, as the intake piping was too long. So just used a couple of zip ties to keep the flexible tube shortened while i fitted it to the afm.
    All i have to do now is buy the filter and start the mod.
    I will most likely buy a cheap filter to start with as i just put my car on gas and it has been backfiring causing the pod filter and the air intake tubing to come apart due to the pressure.
    I replaced the leads and it hasnt backfired since but id rather be careful and start of with a cheap filter rather than a K&N just incase it does backfire again and blows my filter to bits.
    or will a K&N be fine? lol
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    Pod filters = fail.
    Panel filter = good.
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
    VL Executive
    Feb 2009
    Craigmore SA
    yeh im definately going with a panel filter now, just have to decide which one
    from reading around the posts ive gathered K&Ns arnt that great so probably just go with a stock one
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Good choice due I'm about to give my K&N panel filter to a mate and whack a Lukey panel filter in.
    VT spac super6
    Nov 2008
    Riverton sa
    get a decent panel filter, and run a cai ou into the bottom of the airbox from the front bumper like so..
    VL Executive
    Feb 2009
    Craigmore SA
    Quote Originally Posted by HARVZ-6 View Post
    Yeh that is what coastvls guide is on. Thanks
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    watch the backfiring it can blow out the tiny hot wire in the AFM causing your AFM to shit itself.
    Panel filter i would suggest k&N ive had mine for years and its been great.
    dont overoil them and clean them regulary... better than that shitty cheap paper one.
    have a look in some autobahns i have seen them in a display showing the airflow between the paper ones and a K&N with a ping pong ball in a tube shows u how far it moves up in the tube good comparison
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    Default K&N panel filter
    Quote Originally Posted by owen18 View Post
    i have a K&N panel filter near new only done like 12,000 or so kms if that sitting in my shed if you wann buy one cheap PM me if your keen, i have a few parts sitting in they and need them gone
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    ill give u 2nd hand one out of an rb25 i think its from..''still fits'' for free u just pay postage its k&n though its purple and there yellow filters?
    i have a Drift pod in a skyline box lol! ill have to get a pic
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
  15. #15
    VL Executive
    Feb 2009
    Craigmore SA
    hey no thanks guys i already have a filter. Thanks anyway though
    I did the cold air intake through the guard and to the grill, following coastvls guide.
    It seems to be running much better, however on gas the revs drop to 0 after accelarating, although it doesnt stall.
    Im guessing that its just the mixtures for the gas need to be retuned as more air is coming in... so i will hopefully get that done in next few days.
    Does anyone have any ideas on what else it could be though??
    I thought if i disconnected to battery to reset everything it would be ok but never helped.
    Runs awesome on petrol though
    Thanks
  1. Is it hard to change my valley cover and rocket cover gaskets
    By eagle13 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-03-2010, 09:39 PM
  2. pollen filter/air con filter
    By binghy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-05-2009, 11:45 PM
  3. Car / Ute Cover
    By SSMarine in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-06-2006, 04:24 PM
  4. Car Cover
    By savage1987 in forum General
    Last Post: 09-03-2006, 08:43 PM
  5. STandard AIr filter or K&N POD/FIlter
    By KDB1972VT in forum General
    Last Post: 29-07-2005, 11:16 AM
