a hose clamp
hey guys,
completing my build from na to turbo and im putting the standard intake pipe from turbo to afm it goes over the turbo inlet housing but moves around abit and doesnt clamp tight..
was there somthing from new that went around there and created a seal of some sort and clamped tight?
any help or suggestions would be greatly apreciated.
cheers
a hose clamp
i got the hose clamp it ise tack welded to the pipe and only tightens so much. the standard intake pipe has a few slits in the metalthat alow it to clamp to a certain extent. when its on the turbo its moving around abit thats wy i think i need somthing rubber that withstands the heat over the inlet housing
let me know
