+ Reply to Thread
Results 1 to 11 of 11
Thread: manual conversion help please
    Cal-a is offline wicked sick Cal-a Executive
    1986 vl executive, 88 vl executive
    Feb 2009
    in Warburton, victoria
    Default manual conversion help please
    hey guys probaly been answerd alot before but
    but after just puting the manual box in and puting the clutch, clutch box and bolting it all up my car will not start with the key however it does start with the screwdrive trick on the starter motor and role starts and idles fine, it just doesnt start with the key.
    also after doing this conversion the backing lights in my dash do not light up the switch doesnt seem to be broken as it still turns the interior light on
    it is just a stock standerd vl executive 88 model
    anyhelp would be awsome
    azzfox's Avatar
    azzfox is offline slideways azzfox Caprice
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    What have you done now! lol good to see you finally went ahead with it!
    Unsure if VL's have an inhibitor switch, but Im guessing so, and you need to short out this wire. (switch at base of auto selector to stop car starting when not in Park or Neutral)
    Dash lights may have something to do with this area also. The console lights are wired with the dash lights.
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    bf xr6 daily, vl project, wb ute project
    Aug 2008
    QLD
    bridge the purple wires from the battery (neutral switch for the auto box)
    theres another thread on this conversion in here by goon that has some good info in it.
    you're dash lights could be a million things, i would be looking for shorts somewhere or a fuse, start simple then work up.
    VT spac super6
    Nov 2008
    Riverton sa
    next to the battery is a few relays, one has to thick purple wires running into it, cut and join
    also a good place to fit a kill switch (Y)
    Feb 2009
    harvz-6 i did what you said looked and cut the 2 purple wires coming out from the relay but still nothing
    and for some reason my central locking doesnt work anymore
    Aug 2008
    QLD
    is the central locking aftermarket or from a berlina/calais?
    edit: did you check your ignition barrel wiring when you pulled out your auto pedal box?
    VT spac super6
    Nov 2008
    Riverton sa
    so everything else works with the ignition?
    have you checked the started relay?
    Feb 2009
    yeah vrythin works with the ignition except for kicking it over
    where abouts do i find the starter relay is it the same ones the purple wires come out of
    Feb 2009
    ok whats wrong with my car
    no dash lights
    no central locking
    car doesnt start with the key
    what i have done is join the 2 purple wires and still nothing
    i never removed the pedal box as you dont have to to fit the clutch pedal in
    can someone please guide me through on what to do
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    I think its something to do with the central locking. By any chance is it an immobiliser too? And arent the headlights/parkers connected to the central locking from memory instead of indicators? Do they still work or is it only the dash lights?
    My (ex)Ride
    Aug 2008
    QLD
    I don't have central locking, but I had something like this happen once, my headlights/dashlights would turn on for a few seconds, then *click* circuit breaker would cut out - no lights.
    Turned out to be a short in my towing lights plug, and apparently thry're all on the one circuit. If what azz is saying is correct, and the central locking is on the same circuit as the lights, then i would be looking for something along the lines of a short or more likely an earth that has come loose somewhere...
    Is taking it to an auto-electrician a possibility?
+ Reply to Thread
  1. Please Help, Doing manual conversion and i used the auto flexplate bolt on manual fly
    By xtreme_sony in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-06-2009, 07:52 PM
  2. [SA] VN S1 Manual Conversion Kit
    By Snakes-Calais in forum Parts And Other Items For Sale
    Last Post: 18-01-2009, 03:18 PM
  3. Manual conversion
    By Stephen_Vn_Exec in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-04-2007, 11:24 PM
  4. WTB: Manual conversion or wrecked vn-vr manual
    By na3point8 in forum Parts And Other Items For Sale
    Last Post: 13-03-2007, 10:22 PM
  5. Vp manual conversion and vn auto conversion
    By gumbs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2005, 10:08 PM
