+ Reply to Thread
Results 1 to 14 of 14
Thread: got a silly starting problem plz help
    vl rb30e
    Jun 2009
    Thumbs down got a silly starting problem plz help
    just converted my vl to a manual and it cranks ive got spark but my fuel pump relay keeps clicking and my injecters pulse is gone wak need help plz
    vl rb30e
    Jun 2009
    please help sos!!!!!!!!!!gotta drive 3 hours tommorow and just sold my other car need it goin thanks
    VT spac super6
    Nov 2008
    Riverton sa
    check for fault codes on the computer
    nothing involved in the conversion effects the engine management
    have you tried swapping it with another relay?
    and check cas sensor aswell
    vl rb30e
    Jun 2009
    will the cas being dirty stop the fuel pump goin or throw the injecters out of wak
    VT spac super6
    Nov 2008
    Riverton sa
    wont effect fuel pump, will effect injector pulse, its timing is controlled by the cas
    GetToDaChopa is offline Blues Brother # 2 GetToDaChopa Berlina
    The Blues Mobile
    Dec 2008
    Western Sydney
    VT spac super6
    Nov 2008
    Riverton sa
    vl rb30e
    Jun 2009
    turns over fine just wen u stick a circuit tester in the injecter plug it comes up as both little female prongs inside the plug both being positives instead of one positive one negative but one injecter plug is correct the rest are wak
    VT spac super6
    Nov 2008
    Riverton sa
    the all fire together it ones fine and the rest arent, its a wiring problem
    vl rb30e
    Jun 2009
    VT spac super6
    Nov 2008
    Riverton sa
    id check the computer for faults first,
    if nothing comes up id check cas sensor
    vl rb30e
    Jun 2009
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher VL Berlina 5speed Monaro VL Berlina 5speed Monaro
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    both injectors will be possitive but when the dissy spins and activates the pulse the system uses the reverse polarity relay to convert one power too a -12v and allows the pulse for the duration
    try swapping the metal relay down in your guard near your battery but makes sure its the same type,
    the dissy also does run the fuel pump
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver detox_nath83 Executive
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    possibly bad earth under relay plug. pull it out and check wires crimped onto spade connectors.
    Generally clicking relay means either 2 things
    Bad earth or stuffed relay
    or both
    :P
+ Reply to Thread
  1. starting problem
    By big balls in forum General
    Last Post: 27-01-2009, 12:02 PM
  2. starting problem
    By djeyecon in forum V6 Development And Modification
    Last Post: 29-07-2008, 10:13 PM
  3. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 08:56 PM
  4. Help Please.v8 Starting Problem
    By v8srbad in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-04-2007, 06:59 PM
  5. Vn Starting Problem
    By keatz_RedVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-04-2004, 01:03 AM
