+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 26 to 33 of 33
Thread: help asap vl not firing
  1. #26
    winton's Avatar
    winton is offline black+manual+19's=sex winton Executive
    vs SS II 5speed vx gts 19's
    Apr 2007
    modbury
    umm not sure ill cheak today
    new car: 96 vs SS II BLACK+5 SPEED
    http://forums.justcommodores.com.au/...ad.php?t=57053
    ^^^cheak it out^^^
  2. #27
    vp v8 bt1 5 speed
    Jun 2009
    adelaide sa
    told ya its only worth $500 mate lol ha ha ha ha get rid of jap engine and it would all be right sorry dude beached as
    weres our track you a*** holes
  3. #28
    winton's Avatar
    Apr 2007
    modbury
    Quote Originally Posted by holdenmanv6vrv6 View Post
    ur a sik **** ay u got a vr v6 fk off if ur not gonna post to try help me dont even bother
    ^^^cheak it out^^^
  4. #29
    Jezza's Avatar
    Jezza is offline Ecotec Just Kicked In! Jezza Berlina
    VYII Acclaim
    Apr 2009
    South Australia
    have you tryed the ignition module because i bought my first car recently and it needed a ingition module because it wouldnt start, it would try to but no luck then when we put the new one on it started first time and it only cost $80
  5. #30
    winton's Avatar
    Apr 2007
    modbury
    na i havent tryed that i did a error cheak and one of the codes was ignition problem .. u rekon thats y
    ^^^cheak it out^^^
  6. #31
    Jezza's Avatar
    VYII Acclaim
    Apr 2009
    South Australia
    well it sounds like a similar problem and my mechanic said when i was getting the ignition module that if its starting but not turning over that its one of the first things you check so thats my guess on it
  7. #32
    VL Berlina soon to be turbo'd
    Mar 2005
    Whyalla ..
    Default Free to look
    Hi all i had same problem with my old vl had spark and petrol just wouldnt kick over i spent hours looking at it only to find when i was changing the plugs i cracked the line that goes from the rocket cover to the intake tubing (one that goes at the back of the rocket cover and neer the throttal body) turns out wasnt getting correct air mixture and wasnt firing replaced it with garden hoes off she went no probs at all
    could be as simple as that had me spinning for a bit hope it helps
  8. #33
    1988 VL Commodore (Wagon)
    Jul 2009
    I doubt it is the dizzy, it has to be a fuel delivery problem. Check your fuel pump or the regulator. Also muffman's suggestion makes a lot of sense.
+ Reply to Thread
  1. Firing Order V6 VR
    By patullose in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-12-2009, 09:49 PM
  2. Hq 5.0 firing problem
    By hq-racing in forum General
    Last Post: 01-04-2009, 08:01 PM
  3. VS V6 mis-firing ??
    By peejay71 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-09-2008, 08:50 PM
  4. Not firing
    Last Post: 27-05-2008, 06:57 PM
  5. VK 202 firing order?
    By scott's ass in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-08-2006, 09:28 PM
