+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 33
Thread: help asap vl not firing
    winton's Avatar
    winton is offline black+manual+19's=sex winton Executive
    vs SS II 5speed vx gts 19's
    Apr 2007
    modbury
    Default help asap vl not firing
    i got vl turbo and its cranking but not kicking over i recently changed the dizzy and coil to get spark but not happening what other reason y this would happen
    new car: 96 vs SS II BLACK+5 SPEED
    http://forums.justcommodores.com.au/...ad.php?t=57053
    ^^^cheak it out^^^
    VT spac super6
    Nov 2008
    Riverton sa
    checked the computer for faults?
    vl rb30e
    Jun 2009
    check ya crank angle sensor give it a clean mate.
    winton's Avatar
    Apr 2007
    modbury
    how do i cheak comp for faults
    ^^^cheak it out^^^
    vl rb30e
    Jun 2009
    ya need a workshop manual mate or get on google.
    winton's Avatar
    Apr 2007
    modbury
    yer i got the workshop manual
    ^^^cheak it out^^^
    VT spac super6
    Nov 2008
    Riverton sa
    its in the engine management section mate,
    easy to follow
    good luck!
    vl rb30e
    Jun 2009
    go to the chapter problem diagnoses and follow it from there
    winton's Avatar
    Apr 2007
    modbury
    sweet as ill have a look through it... any other reason y it wouldnt be firing.. just keeps cranking and cranking and cranking
    ^^^cheak it out^^^
    VT spac super6
    Nov 2008
    Riverton sa
    so it does have spark?
    sounds stupid but how much fuel has she got? iv had myne a few times get so low it refused to start again..
    vl rb30e
    Jun 2009
    ya mite be better off just to get a new cas or one that wrecker nows it works and change it
    winton's Avatar
    Apr 2007
    modbury
    i recently put 10L of fuel in it i was driving away from petrol stration when i tfirst ****ed up.. yer i rekon i mihgt have to get a new cas.. could i tbe dizzy or coil? coz i got told it was that so went to u pull it and got em
    ^^^cheak it out^^^
    VT spac super6
    Nov 2008
    Riverton sa
    just check and see if shes gettin good spark
    cas sensor will generally stop firing all together..
    with that much itd atleast fire so that rules out fuel..
    vl rb30e
    Jun 2009
    give everything a good clean ad let it dry out properly then put it all bak on give that a go
  15. #15
    vr
    Jun 2009
    adelaide sa
    Talking v8 munchn
    ill give ya $500 need to update to something newer
  16. #16
    winton's Avatar
    Apr 2007
    modbury
    add an extra 0 to that and id think about it lol
    ^^^cheak it out^^^
  17. #17
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher VL Berlina 5speed Monaro VL Berlina 5speed Monaro
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    have yiou got the dissy timming set correct?
    by setting motor on tdc on compression stroke and rotarty arm too point 1
    wheres a quick test, with your spare dissy plug it into the CAS plug and put the disy cap on with all the leads
    turn the ignition on and turn the dissy by hand
    this will cause the engine to spark at each plug depending where the rotary point is
    will cause the injectors to pulse and the fuel pump to run
    if you get no injector pulse park it means the CAS loom is not getting good signal to the computer hence no fire
    try this first and work from there
    just re read your post and def try the hand spining dissy
    im thinking it could be the CAS plug/loom
    normally these get brittle and corrode cause the car to die all sudden or start and stall
    it the plug on top of the dissy, wiggle it while someone turns it over
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
  18. #18
    winton's Avatar
    Apr 2007
    modbury
    yer cheer man what u mean turn dizzzy around u mean just the cap? wont the leads be in the way to turn it around fully or
    ^^^cheak it out^^^
  19. #19
    Oct 2005
    have the dissy out of the engine but have the dissy cap on with the leads and the CAS and little earth cable plugged in
    then by hand spin the splinned end of the shaft
    my replys wont be quick as im watching top gear atm but ill try help you during the adds
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
  20. #20
    winton's Avatar
    Apr 2007
    modbury
    ok yer cool i get ya while someone cranking the car... what will this do should fire ay? if its getting spark
    ^^^cheak it out^^^
  21. #21
    Oct 2005
    wiggling the cas cable will see if the termals are connecting properly and allowing the car to fire
    happened to me before in one of my old vls, died randomly and wiggled the loom and it ran till i hit another bump and it cut out
    simplely i cut in another newer plug
    if these dont connect well you will not get a good if any spark or injector pulse
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
  22. #22
    vl calais,
    Jun 2009
    logan
    change the dissy model, most of the time its that
  23. #23
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver detox_nath83 Executive
    VL Turbo Commo
    Sea Dogs Champion! X-Bound Champion!
    Aug 2005
    Queensland(Sunny Coast)
    also if CAS and AFM are fine could be possibly the Power transistor(Black Bit with T plug on dizzy) this works to switch the coil to produce spark.
    i would lean towards CAS.
    i had a problem a while back check my thread (vl not starting tried the obvious)
    i came across it was the power diode in the loom near battery was corroded out and was turning off my injectors.(diode there for reverse polarity protection)
    i have left it out and had no probs. as soon as i connect the wire where it was it shuts of injectors and stalls.
    As for CAS plug pull back the rubber boot and check where the wires are crimped on to spade connectors. can corrode in there.
    Do same with AFM plug spray both with Inox/wd40/rp7 etc
    also what previous posts have stated check your timing
    Goodluck
  24. #24
    winton's Avatar
    Apr 2007
    modbury
    oil smells like petrol!.. plugs black as!.. hardly any compression (havent done comp test tho).....rings gone maby??
    ^^^cheak it out^^^
  25. #25
    delcowizzid's Avatar
    delcowizzid is offline BAD COP! - NO DONUT!!! delcowizzid ClubSport delcowizzid ClubSport
    в∞ѕтεכ √&
    Jul 2008
    NZ
    is the dizzy actually spinning when you wind it over and the cam may have snapped belt
    Quote Originally Posted by savage1987 View Post
    You're the reason I believe the youth of today are largely retarded.
+ Reply to Thread
  1. Firing Order V6 VR
    By patullose in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-12-2009, 09:49 PM
  2. Hq 5.0 firing problem
    By hq-racing in forum General
    Last Post: 01-04-2009, 08:01 PM
  3. VS V6 mis-firing ??
    By peejay71 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-09-2008, 09:50 PM
  4. Not firing
    Last Post: 27-05-2008, 07:57 PM
  5. VK 202 firing order?
    By scott's ass in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-08-2006, 10:28 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79
