Results 1 to 13 of 13
Thread: VL Commodore losing water
    1992 VP Executive
    Jul 2009
    Default VL Commodore losing water
    Hey..
    I have a '88 VL commodore 6cyl that's losing water.
    When it's idling, the water runs out of the top of the radiator and bubbles a lot.
    When you turn the engine off, the water level goes down out of sight, and it needs to be topped up again.
    I had it running for about 15-20 min, and the converter for the gas system froze up.
    I cant see any leaks externally from the cooling system.
    Any ideas?
    Cheers,
    Mike
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    you need to top it up with the engine running and the heater on, I use one of those large $2 funnels you get with the flexi hose on the bottom, take the flexi hose off and attach a piece of radiator hose that fits nice and snug in the radiator spout, this way the water level is above the top of the engine.
    run the engine until the heater blows hot air and the top radiator hose is warm top it up and give it a few light continuous revs about 2000rpm make sure there are no bubbles remove funnel replace cap all done.
    if you continue to lose water and no leak is evident you can assume it is going through the engine and out the exhaust = cracked head, cracked block or blown head gasket.
    idling the car for extended periods on gas will cause the gas converter to freeze over because without the higher revs very little water pumps through the converter to stop it freezing.
    Nobody wants to play with me
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    also look along all your welch plugs intake and exhaust side as well as small ones in head for evident water loss. if u let it down too low make sure you bleed the bolts first one near thermo housing and second up on top of intake plenum. if u dont then will surely get a cracked head in due time.
    vl berlina wagon 6cyl
    Jul 2005
    I have a water loss also and cant see where its leaking, have checked everything and replaced radiator cap in case pressure spring was worn, also added leak stopper chemicals
    can the cooling system be pressurised or is there any way of working out where its leaking
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    you can pressure test the cooling system through the overflow pipe near the radiator cap. you need a pump and an accurate pressure gauge maximum pressure for the system is 105kpa.
    1988 VL Commodore (Wagon)
    Jul 2009
    Is there any rust on your radiator? Near the top? I'm guessing you have a pinhole leak in the rad, check it out. Also do you get water jetting onto the windscreen at times?
    Clean your expansion tank and check the radiator for leaks.
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    tighten all possible water pipes top and bottom hoses of rad as well as the hoses at the block. also heater hoses .
    overflow hose from rad along under plastic trim infront of radiator where radiator shroud is(plasic clips holding It down) could be a pin hole in this line.
    as well as radiator. c a rad man he will put a manual pump on where your rad cap goes and pressure test it.
    if there is no evident fluid loss from seeing coolant it could be dropping onto exhaust or somewhere hot and vaporising.
    No Milky oil????(cracked head)
    Jul 2005
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    maybe the heater core is leaking as well, thats happened to a few people. Its baffling when that happens cause you wont see and water in the engine bay
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
    Jul 2005
    I replaced the hose from top of radiator to plastic catch tank and the leak seems to ahve stopped, perhaps there was a hole in the hose so water was leaking down front of radiator where I couldnt see it
    also noted that the clip holding hose to radiator is a spring type that had weakened over the years
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Yeah ive found tighten up the clamps by hand isnt always a job done, as ive used the drill and been able to tighten stuff up further..
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    just be carefull with drill.... set the clutch(not full drive) so you dont cripple/crimp the hose or pipe.
  1. Losing Coolant
    By Tom_1569 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-03-2009, 07:43 PM
  2. VS V6 losing oil pressure
    By Goum in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-02-2009, 03:51 PM
  3. Losing Water from Radiator?
    By VXdarkmagic in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-11-2008, 04:46 PM
  4. water disappearing - water pump - how to change?
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-07-2008, 01:30 AM
  5. losing coolant
    By Panama in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-03-2008, 10:31 PM
