Results 1 to 19 of 19
Thread: Vl Having troubles plz help me
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    Default Vl Having troubles plz help me
    Hey there pplz,
    Ok now i went to start it the other day and had no spark, so i thought it was the CAS so i changed the distibutor and it started but ran like shit. (The dizzy was out of running car).
    So i put the original dizzy back in just to try it and it went, i just had the timing done yesterday by a mechanic and he said give that a go..
    So it went alright for about half an hour till we went to big w straight after we left the mechanic, we where at the shops for about half an hour to an hour, walked back to the car and went to start it had trouble starting and it was like it wasnt getting any fuel, but i got it going and it ran like shit again for about 5 minutes,
    after that it went like normal. This morning i got up and went out to start it.....and guess what it wouldnt start!!!
    If any one has any ideas can they plz help me!
    Nackerz's Avatar
    Jul 2009
    Now i have just checked the coil for spark, its got a weak orange spark every now and then but not sparking blue constant.....what could it be need help asap as need car going coz the misses has the other vl at work
    VT spac super6
    Nov 2008
    Riverton sa
    Nackerz's Avatar
    Jul 2009
    Yea just went and got some spares out of my spare parts car, I grabbed the coil, CAS, And the module on the side of the distributor with the t piece plug i gunna try them tomorrow as it is dark and cant see what im doing...
    what do you reckon i should try first the coil??
    Cheers in advance coz your the only one thats helped me so far
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    the CAS controls the injector pulse, Spark and makes the fuel pump run
    if you swapped the dissy with one which has been working fine then one would think is the CAS making connection to the computer
    wiggle the plug for the CAS, so times the connections inside the plug corrode and dont connect or have bad connections causing many things
    not starting, running fine sometimes and suddenly stalling
    as for the weak spark check all the plugs are on good and the leads are on good,
    no harm changing the coil with a spare
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Nackerz's Avatar
    Jul 2009
    As for the spark i pulled the coil lead off the dizzy and stuck a screwdriver in the lead and stuck it 5mm away from the bracket that you pull the motor out with and thats how i checked the spark, so i try with the other coil and see how it goes...
    as for the CAS... the petrol pump is working not sure about injectors but can smell the fuel there and for the spark thats cot me stuffed!!!....for the moment anyway until i check it out tomorrow
    Nackerz's Avatar
    Jul 2009
    OK here's the outcome of changing the coil as for that its got me stuffed as there is still no spark through the coil lead its a faint orange spark...
    Forgot to add that i going to change the coil lead on my running vl
    vl berlina wagon 6cyl
    Jul 2005
    a common problem with crank angle sensore is corrosion in the electrical plug on top of it
    Nackerz's Avatar
    Jul 2009
    Ok thanks for all you guys help, i just had a fiddle with it it took like 2secs to fix, well after changing the coil in the dark i tested with a screwdriver in the end of the coil lead, i noticed a spark where it clips into the timing housing bracket,
    so......... i changed the coil lead and tested that it didn't do it, but still had a weak orange spark, i thought i would check the plugs (not spark plugs) for the coil and the part on the side of the dizzy, all i did was get a small flat head screwdriver and close the female plugs a little bit so it would be a tighter connection, im pretty sure it was the one for the coil as it was pretty loose....
    YAY..The car is up and running again... Cheers for all your help!!!
    NOTE: The second image has been modified by me in paint as it has plates on the car and so noone knows where it was taking.
    Attached Thumbnails Attached Thumbnails Vl Having troubles plz help me-vl.jpg   Vl Having troubles plz help me-pic-0001.jpg
    Nackerz's Avatar
    Jul 2009
    Just went to start it again and nothing just turned over and over so i adjusted the timing and it fired up straight away, so im guessing the timing is a must have spt on or will not go
    Nackerz's Avatar
    Jul 2009
    Hey all BACK to square one again its giving me the shits just went for a drive and its cutting in a out so its got me stuffed
    1988 VL Commodore (Wagon)
    Jul 2009
    You probably need to replace the CAS too, pull it out and see if it has a whole bunch of red gunk built up on it from the old dizzy.
    I've heard that if the CAS goes then the dizzy usually needs to be replaced , you seem to have done it backwards to the usual order but I'll bet that this is your problem.
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    there is no need to replace the whole dizzy it is just a housing for the cas and two bearings, a cas kit is about $80-$100 cas and 2 bearings EASILY change yourself, a new dizzy is $450 and all you get is new cas and 2 bearings already installed.
    Nobody wants to play with me
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    as has been mentioned a few times, it's most likely corrosion on the connector for your cas (or AFM)
    get some contact cleaner spray, pop off the connectors for cas and afm, spray it on, and then plug/unplug like a madman so that the contacts all clean up
    then get some compressed air and blow away all the contact cleaner, and she'll be mint
    rumor has it that the PVC tape or glue or something used in the VL loom aids corrosion of the terminals.
  15. #15
    Nackerz's Avatar
    Jul 2009
    well there is no corrosion so that rules that out complete i am about to change the CAS and see how i go let you all no
  16. #16
    Nackerz's Avatar
    Jul 2009
    Thumbs up
    Quote Originally Posted by VLWALKY View Post
    Hey there pplz,
    Ok so i just changed the CAS out of this dizzy and put it in the walky and turned the key started and runs like a dream
    Cheers for all your help guys i will let you know more on how it goes
    Thanks again
  17. #17
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    power transistor possibly on dizzy. little T shape plug goes on its contacts(little black square looking thing)
    as well as mentioned CAS plug. Have you pulled back the boot on the CAS plug and checked the back of the spade connectors where the wires are crimped. thats a common place for corrosion.When you changed the CAS did you make sure u put the metal disk back in properly and not flipped it.??? making sure it is clean with no debris and grease on it.
  18. #18
    Nackerz's Avatar
    Jul 2009
  19. #19
    Jul 2009
    Quote Originally Posted by VN_Luke View Post
    You sir have been awarded one internet.
    Nice work!
  1. VL troubles
    By maxpower QLD in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-09-2008, 07:27 PM
  2. key troubles
    By alan smithy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-08-2008, 12:45 PM
  3. v6 troubles
    By VTPREDATOR in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-05-2008, 01:01 PM
  4. vn troubles
    By william19 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-04-2007, 06:16 PM
  5. Car Troubles
    By theused084 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-05-2006, 06:35 PM
