Results 1 to 3 of 3
Thread: starting probs help please
    maginoodle's Avatar
    maginoodle is offline Donating Member
    vy series2 ss crewman
    Apr 2006
    Default starting probs help please
    Hi all,
    got given a vl for a paddock basher, first time i have ever worked on one(i dont even remember ever being in one).
    it is an auto.
    when i turn the key the starter doesnt go. it is auto, i tired moving the tbar through all the gears and it didnt cut in. went to check if the neutral switch is connected, thought it would be on the tbar but it isnt, is it on the box? or is it connected to the cable looking thing that runs through the firewall?
    i have checked the fuses, and screwdrivered the starter and it works.
    i couldnt hear the fuel pump so i got underneath, i was told that there is supposed to be an internal and external pump and the external one was missing. i took the internal one out and hooked it up to a batt and it didnt work so i macguyvered a vn pump into it so that should have enough pressure to run the motor.
    the fuel pump still doesnt work with the key on.
    is there something that would cause both these problems?
    i didnt get time to use a test light to check power at the relay, i will do that in the morning.
    Any help appreciated.
    Cheers Shane
    heres my ride, i know its not much but its mine
    http://forums.justcommodores.com.au/...-ss-crewy.html
    and heres my new project
    http://forums.justcommodores.com.au/...ml#post1104629
    VT spac super6
    Nov 2008
    Riverton sa
    check all the relays first off mate
    you can bypass the neutral switch near the battery theres a few relays, one has two thick purple wires cut them and join em together
    but id suggest its something else causing it if the fuel pump wont run
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    I would be inclined to check the CAS as i have different troubles trying to get my vl to go and as one off the guys said to me it runs the petrol pump the starter and spark so if u have none of this its the CAS which is the crank angle sensor found in the distributor
  1. VP Starting probs.
    By *VNCPTR* in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-06-2008, 01:50 PM
  2. vt starting probs
    By vpssguy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-01-2007, 04:47 PM
  3. vs starting probs
    By bennyc10 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-04-2006, 08:51 PM
  4. more help please - Vt starting probs
    By LAUREN in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-04-2005, 08:02 PM
  5. vk starting probs
    By nezza in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-06-2004, 10:07 PM
