1. Air flow meter: check the connections including rubber boot, clean with contact cleaner if necessary. remove the airflow meter (undo the clamp behind it and remove the top of the airbox and air flow meter together) and clean using contact cleaner or some other cleaner thats safe on electrical components. clean out the airbox and replace the air filter if necessary ($10 for a cheap one, $100 for K&N) reinstall everything
if the car is stalling after starting or seems to be choking still after this, check AAC valve, air regulator, make sure there's no air leaks, then replace the air flow meter ($20-$60 from wreckers, approx $150 reconditioned, about $400-$600 new)
TO CHECK AND ADJUST MIXTURE:
1. start and run the engine until its at operating temperature
2. set idle speed and timing to specified values
3. take off the passenger kick panel to view the LED's on the ECU
4. start and run the motor at 2000rpm for 2 mins
5. check the flashes from the LED's on the ecu while at 2000rpm, they should both flash together more than 5 times every 10 seconds. if they don't you have ecu or oxygen sensor issues (refer to the picture at the bottom explaining the interpretation of flashes other than what are stated)
6. if there are more than 5 flashes per 10 secs, stop the engine, disconnect the wiring connector from the AAC valve and the throttle switch
7. start and run the engine at 2000rpm for 2 mins
8. let the engine idle
9. the leds should now flash simultaneously
10. if the green light is flashing more the mixture is lean, if the red is flashing more the mixture is richer than it should be.
10. if the LED's do not flash together remove the plug next to the Air flow meter connector and adjust the screw until they flash together (clockwise raises the resistance and leans the mixture, anti clockwise lowers the resistance and richens the mixture)
11. replace the plug, replace the AAC and throttle switch connectors and return to instruction 4. do the test again to check that the mixture is now right
12. if the mixture cannot be adjusted so that the leds flash together, its time to test the AFM
TO TEST AFM:
pull back the rubber boot on the AFM connector revealing the wires. grab your multimeter and stick the probes on wire 4 (white) and 2 (1 being the closest to the airbox) with the multimeter on DC voltage. turn the ignition on and the voltage reading should be between 1.26V (lean) and 1.32V (rich). this is the base setting and if it is out then the AFM wont be able to be adjusted to a satisfactory mixture (meaning you need a new one)
and just for interests sake you can test the mixture by putting the probes on wire 1 and 3 with the key on and measuring the voltage. 3.6V is the factory setting which is lean, with 2.0V being rich. the mixture should be in the vacinity of 2.0-4.0i couldn't get the LED's to flash and therefore couldn't set it using the computer so i did it this way and set it to 3.5V (AFM resistance of 375 ohms) and then checked it using the computer and it was right, LED's flashing together.
