Results 1 to 7 of 7
Thread: confusing myself
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    Default confusing myself
    well got all the timing belt off because my cam timing is off
    now im confusing myself and my gregorys is just contradicting itself on the two pages
    so thoughts?
    i have the crank mark set even on the marking for the oil pump housing
    the cams dowel mark is not vertical like it says it should be, it a little clockwise (too the right)
    new belt has marks on it for the 53 grooves
    had my mum also double check the amount aswel as me 3 times
    counting the first groove (one with the mark) as zero till the next mark (including the marked one) it is 53 grooves
    just how it should be
    but this is where i get confused
    i put the belt on with the belt marks and cam/crank marks lined up
    fits perfect, cant get it more tighter
    but the cam is still off, not vertical
    if i was to make the cam vertical i would be at 54 grooves which is wrong
    should i just make it 54 grooves in the belt so that the cam will be vertical?????
    need opinion asap, with in a hour or soo as im heading out for rest of the weekend
    cheers
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Oct 2005
    all good problem solved
    was trying to get the cam vertical to the ground but the engine is actuall on a slight lean to passanger side and i never noticed it
    got it vertical to the head like it said and all is swell
    just a running issue ive got to find still
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    Oct 2005
    bassically cranks fine and runs for few second and splutters then stalls
    got fuel pumps working,
    fuel pressure
    injectors are clean
    injectors pulse
    new plugs
    cas works
    new leads
    computer gets cas signal
    dissy capcitor changed
    coil pack new
    afm tested/swapped with working one
    tryed diff computer
    cam timming right
    dissy timming right
    no blown fuses or stuffed relays
    no comp faults
    no intake manifold or piping leaks i can find
    compression tested motor
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    Nackerz's Avatar
    Jul 2009
    Just a thought coz i had similar problem have you got a spare CAS just to try
    Oct 2005
    yer done, forgot that in the list
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    Nackerz's Avatar
    Jul 2009
    Have you tried a different coil lead, pull number one lead of and have a screwdriver in it and start and it will run on 5 cylinders, when you are cranking make sure u have constant blue spark and keep watching till it stalls if it has something to do with spark it will die in and out,
    does it idle fine but when you try and rev it, it dies or doesnt it idle, check the plug on afm because if it idles ok and you cant rev it thats your afm, give that a shot and let me know
  1. Petrol Tank confusing..
    By nick3110 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-04-2009, 03:40 PM
  2. Coil pack confusing-HELP
    By Bz Kn33z in forum VN - VP - VG - VQ
    Last Post: 29-07-2008, 07:20 PM
  3. Anyone confusing the VE with another car?
    By Evman in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-10-2006, 02:40 AM
  4. confusing problem
    By ROCKIN VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-07-2005, 02:44 PM
