Results 1 to 8 of 8
Thread: need people too check
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    Default need people too check
    after a quick hand here
    can people check there rear bar and tell me if there is a factory recess on the bar for the tow bars
    bellow the number plate on the bottom edge
    cant recall if my old bar had it and only noticed it while sanding mine today
    cheers
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    is it a standard rear bar or not...and there are different types of tounges too i had to get one made for my car
    bf xr6 daily, vl project, wb ute project
    Aug 2008
    QLD
    Ok so on my daily I have the le kit, which has no allowance whatsoever for a tow bar, but I have 2 spares, one genuine which has a little cut out recess for the tow bar, and a non-gen one that does not have the recess..
    Hope that helps?
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    86 VLCT/ 03 II VY SS Ute
    Aug 2007
    yeah my calais had one and so does my wagon. pretty sure its factory sean
    VL Wgn & VL Sdn
    May 2009
    The Shed...W.A.
    Seem's they all have them...?
    Both mine have them, 87(wgn) an 88(sdn) , mind they are both Executives tho
    Regards oldboi
    vl berlina wagon 6cyl
    Jul 2005
    BTW when I fitted my towbar there was a white plastic spacer under a bolt that held the fueltank strap that was meant to be removed and replaced with a towbar mounting plate
    the metal was very thin as I drilled the holes and remember the VL is known for stretching the floor from heavy towing
    Oct 2005
    cheers all for the help in checking
    never really picked up on it before
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
  1. What do people look for in VL
    By hz2vl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-01-2009, 08:32 PM
  2. People that p**s you off
    By shumway in forum The Pub
    Last Post: 06-03-2007, 05:56 PM
  3. Some People
    By Sabbath' in forum The Pub
    Last Post: 12-09-2006, 06:12 PM
  4. hello people im new to here
    By DVX_38L in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-07-2006, 11:07 PM
  5. Need Help People
    By Joey_21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-02-2006, 09:34 AM
