Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Thread: is my engine on its way out? or is it the computer?
    Jezza's Avatar
    Jezza is offline Ecotec Just Kicked In!
    VYII Acclaim
    Apr 2009
    South Australia
    Default is my engine on its way out? or is it the computer?
    Problem 1: my car is running rough first thing in the morning (sounds lumpy when reving it a bit) but it will be cured by reving it upto 5k rpm which i dont want to do every morning
    Problem 2: now im filling the car up with BP Ultimate and have been doing so since it was registered on the road 5 weeks ago and im only getting 200kms in 1 tank and this weeks tank is looking like only 130kms from full
    Problem 3: i have recently bought a 2.5 inch catback and its now as black as hell on the inside and the back of my car has black spots appearing on it
    now i have no idea where to start and what could be wrong being my first car but after i told my mechanic he made a adjustment on the fuel air mixture but that hasnt worked so im asking here if anyone has an idea if maybe the enigne is on its way out (only done 180,000kms on the dash) or if the computer needs replacing
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    ruff at the start,
    when was the plugs last changed? might be a little gummed up and when first starting it you notice it as they havnt burnt any crap off
    excessive fuel try the afm first
    1. Air flow meter: check the connections including rubber boot, clean with contact cleaner if necessary. remove the airflow meter (undo the clamp behind it and remove the top of the airbox and air flow meter together) and clean using contact cleaner or some other cleaner thats safe on electrical components. clean out the airbox and replace the air filter if necessary ($10 for a cheap one, $100 for K&N) reinstall everything
    if the car is stalling after starting or seems to be choking still after this, check AAC valve, air regulator, make sure there's no air leaks, then replace the air flow meter ($20-$60 from wreckers, approx $150 reconditioned, about $400-$600 new)
    TO CHECK AND ADJUST MIXTURE:
    1. start and run the engine until its at operating temperature
    2. set idle speed and timing to specified values
    3. take off the passenger kick panel to view the LED's on the ECU
    4. start and run the motor at 2000rpm for 2 mins
    5. check the flashes from the LED's on the ecu while at 2000rpm, they should both flash together more than 5 times every 10 seconds. if they don't you have ecu or oxygen sensor issues (refer to the picture at the bottom explaining the interpretation of flashes other than what are stated)
    6. if there are more than 5 flashes per 10 secs, stop the engine, disconnect the wiring connector from the AAC valve and the throttle switch
    7. start and run the engine at 2000rpm for 2 mins
    8. let the engine idle
    9. the leds should now flash simultaneously
    10. if the green light is flashing more the mixture is lean, if the red is flashing more the mixture is richer than it should be.
    10. if the LED's do not flash together remove the plug next to the Air flow meter connector and adjust the screw until they flash together (clockwise raises the resistance and leans the mixture, anti clockwise lowers the resistance and richens the mixture)
    11. replace the plug, replace the AAC and throttle switch connectors and return to instruction 4. do the test again to check that the mixture is now right
    12. if the mixture cannot be adjusted so that the leds flash together, its time to test the AFM
    TO TEST AFM:
    pull back the rubber boot on the AFM connector revealing the wires. grab your multimeter and stick the probes on wire 4 (white) and 2 (1 being the closest to the airbox) with the multimeter on DC voltage. turn the ignition on and the voltage reading should be between 1.26V (lean) and 1.32V (rich). this is the base setting and if it is out then the AFM wont be able to be adjusted to a satisfactory mixture (meaning you need a new one)
    and just for interests sake you can test the mixture by putting the probes on wire 1 and 3 with the key on and measuring the voltage. 3.6V is the factory setting which is lean, with 2.0V being rich. the mixture should be in the vacinity of 2.0-4.0i couldn't get the LED's to flash and therefore couldn't set it using the computer so i did it this way and set it to 3.5V (AFM resistance of 375 ohms) and then checked it using the computer and it was right, LED's flashing together.
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    vl berlina wagon 6cyl
    Jul 2005
    if the engine is a 6, you need to turn ign on and wait for the fuelpump whine to stop, then with foot off the accelerator, a short run of the starter motor should start it
    the engine runs rough for a while if you dont wait as the injection doesnt have enough fuel pressure
    Jezza's Avatar
    VYII Acclaim
    Apr 2009
    South Australia
    the spark plugs where replaced when we gave it a service after i got it but i will do that test when i have some time on tuesday
    Jezza's Avatar
    VYII Acclaim
    Apr 2009
    South Australia
    well ive found that problem 1 was me forgetting to let the fuel pump whine stop before i started the car and im going to get the other problems fixed tomorrow hopefully
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    ask ur mechanic if he did the timing too, thats another issue u might want to look at.. just a thought!!!
    Jezza's Avatar
    VYII Acclaim
    Apr 2009
    South Australia
    cool thanks for the help and hopefully i will have a better running vl soon
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    Quote Originally Posted by VL3.0L View Post
    getting in the car and starting it straight a way is not the problem, there is no reason for you to wait for the fuel pump to prime unless there are other underlying issues, the vl should start on cold without pause no worries it has a pressurised fuel system.
    you should never rev a cold engine past 2k when starting, and you should not have to touch the accelerator until the car is in gear and you are ready to drive away.
    a workshop manual will tell you how to test the fuel and engine management system to find your problem e.g. oxygen sensor, air flow meter, fuel pressure regulator, idle air controller etc.....
    Nobody wants to play with me
    Jezza's Avatar
    VYII Acclaim
    Apr 2009
    South Australia
    Well we have adjusted the setting and we did this test (below) and the voltage was 3.4 so it was running VERY RICH so we have now adjusted it to 1.29 and we also changed the computer do the spare one it came with which was a genuine vl computer and the pictures below are the one we pulled out and i suspect it was from a R31
    TO TEST AFM:
    HoldenOnn's Avatar
    HoldenOnn is offline Roll Cage Territory
    VZ Calais Alloytec190
    May 2009
    Busselton, WA
    Many many things that it can be. You have to narrow it down. Sounds like the CTS (coolant temp sensor). If your mechanic has been around a while, he will have seen many vls and he will know all the things to check for when you drop the car off. Many items it could be and any long time mechanic should have seen a few vls by now.
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    as well as O2 sensor can cause car to run rich meaning more fuel consumption, AFM settings like 5Speed has stated and CTS 3 majors to check. Have you checked for any moisture along your fuel lines etc. leaking/loose hose clamps... pin hole in steel lines from tank and return line.
    Goodluck
    keep us informed
    Goon's Avatar
    Feb 2006
    GC. QLD
    lol looks like a skyline ecu??? i never seen that label on vl ecu's.. maybe the ecu is giving u problems???..
    Jezza's Avatar
    VYII Acclaim
    Apr 2009
    South Australia
    yeah as i said in my post we have changed the ecu to a one that came (previous owner couldnt get the car to start and replaced alot of things including the ecu and the one in the picture is the original one he found in it) with one that he bought for it but it wasnt needed which is the correct one but it was also the mixture setting which instead of running between 1.26 and 1.32 volts it was running at 3. something which is over double
    Goon's Avatar
    Feb 2006
    GC. QLD
    Fair enough mate, aslong as u got both lights flashing togthere on the ecu, everythings sweet!!
  15. #15
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    Another thing to throw into the mix is the Fuel Pressure regulator...sounds strangely like this also...
  16. #16
    Jezza's Avatar
    VYII Acclaim
    Apr 2009
    South Australia
    well i think ive sorted the problem because i was told that the car uses more petrol till it warms up and my work is only about 10 minutes away so i get to work just as the car has warmed up
  17. #17
    LiamVK is offline Gronnie
    1988 vl series 200
    Oct 2007
    Box Hill North
    i only get about 250km from a tank. just went and checked my AFM and got the reading of 10 volts on wires 4 and 2 and 0.01 on wires 3 and 1. i also have alot of black on my bumper and get a regular smell of fuel. will be getting a new afm tomorrow. i have replaced the coolant tempt sensor also. any ideas of what is wrong or anything to help me get better economy.
    sorry to hijack the thread a bit.
    thanks
  18. #18
    Tasmaniak's Avatar
    car
    Apr 2005
    do people actually check their o2 sensor anymore for issues? Thats the best way to see if your running rich or lean.
  19. #19
    vy2 clubsport
    Feb 2008
    adelaide
    i highly doubt thats gona be causing your exsesive fuel consumption
  20. #20
    86 VLCT/ 03 II VY SS Ute
    Aug 2007
    yeah that def isnt it mate, my work is about 5 mins away and i drive there everyday with car cold and i get 400ks to a tank. and yeah the car does use more fuel when cold but not enough that you are going to notice it that much.
  21. #21
    Jezza's Avatar
    VYII Acclaim
    Apr 2009
    South Australia
    well after reading through this good info on VL not posted here for quite a while i think it is the oxy sensor so im buying one today from motor traders and will install it tomorrow and hopefully notice a difference in the fuel consumption
  22. #22
    Tasmaniak's Avatar
    car
    Apr 2005
    by the socket to go with it and plenty of penetrating spray.
    Have you actually measured the o2 sensor?
  23. #23
    Tasmaniak's Avatar
    car
    Apr 2005
    and look that may not be the problem either! If then engine is not going into closed loop mode that will use excess fuel.
  24. #24
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
  25. #25
    Tasmaniak's Avatar
    car
    Apr 2005
    actually it doesn't. all it tells the computer in that regard is if the o2 sensor is hot enough to operate efficiently enough for the vehicle to go into closed loop mode. What tells the computer to gointo closed loop or not is the ECT and the TPS.
    First things first...stop pumping in hi octane fuel...it ain't helping you. it's only hurting your pocket. Here is my suggestion mate... Before dropping the bills on an o2 sensor. Go and buy yourself a cheap multimeter. Switch ito Volt DC and have it on a setting somewhere be 2Volts and 20Volts. Now, put the black probe onto the negative of the body and force the red one deep into the middle pin of the plug coming out of the o2 Sensor (where it connects ot the main loom.) Now, start the car...this wire will be reading somewhere .0 and point .2 of a volt. within 60 seconds but maybe as long as 5 minutes dependant upon sensor you will see that voltage go up...then it's going to go down...then back up....then back down... catch my drift? It should go upto about .7 and back down to around about .3 and it will go each way about on every two seconds dependant upon sensor. Now if it goes to a certain voltage and really doesn't change at all then we now know the engine is in open loop mode. It shouldn't be there while it's idling...or while it's cruising. It should be in open loop under heavy acceleration and warm up...thats about it.
    A breif run down on the voltages...
    The o2 sensor works like a small battery in that it is unpowered...it creates and sends out it's own electricity. It operates between 0 volt and 1volt. Well actually not quite but pretty damn close so we won[t go into it.
    A reading of over .8 indicates a rich mixture
    A reading of under .2 indicates a lean mixture.
    .45 is stoichiometric
    Closed loop mode is when the voltage fluctuates between .3 and .7 volts. You WANT the car in CLosed loop. Open loop is great for wawrming up the car and getting more power out of the engine during heavy acceleration as it creates a rich mixture condition. Do that and let us know how it goes. we can further diagnos the issue from there....just somehow I don't think it's the o2 sensor. It would be interesting to see where the Long Term Fuel Trim has set itself to on your car mate.
  1. engine computer light keeps coming on
    By carpetsnake in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-11-2008, 02:17 PM
  2. will vp computer run vt engine
    By kiwitrubro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-08-2008, 07:01 PM
  3. vs engine computer
    By vr-man in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-12-2007, 09:20 PM
  4. Will a vr engine and computer run a T700 transmission
    By fullaaa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-02-2006, 11:40 AM
  5. VY Exec + Engine mods + computer?
    By Jman in forum VY Holden Commodore (2002 - 2004)
    Last Post: 10-06-2005, 12:58 AM
