Results 1 to 8 of 8
Thread: Berlina dash cluster into Executive?
    VL 5 speed (sold), VS wagon
    Apr 2009
    south oz.
    Default Berlina dash cluster into Executive?
    I just got myself an 87 VL executive project and want to know if a tacho cluster from a Berlina/Calais will connect straight up in a VL executive dash (without tacho)
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    yes plug it in bud not a worry one big connector on back of cluster and connect the speedo cable.
    easy only 4 bolts holding it in. i done it b4. tacho runs of the coil which would be there already for other models.
    Jezza's Avatar
    Jezza is offline Ecotec Just Kicked In!
    VYII Acclaim
    Apr 2009
    South Australia
    i have done the same thing to my sl recently and it isnt hard just make sure your carefull taking the dash off to get to he cluster but mine had a speedo and clock and my new one has the digital clock and tacho and i havent had any problems
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    3rd'd. put it in and all will work sweet.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    you will need a new oil pressure sender unit tho ur old dash will be a oil light where the tacho dash is a gauge
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
    STEALTHY™'s Avatar
    Jan 2005
    Yours was broken then, mine went in and all gauges/lights worked perfectly.
    cheers sexy
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    fair enough
    VL SL Turbo
    Feb 2006
    the oil pressure sensor needs 2 be changed or your oil pressure will read off the gauge dosent mean its working it means its getting the incorrect signal
  1. berlina dash in executive
    By phoenix_984 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-09-2009, 06:19 PM
  2. VZ V8 SS Cluster Into V6 Executive
    By AussieHolden in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 28-06-2009, 04:59 PM
  3. VS Berlina/Calais Instrument Cluster too Executive
    By jakewaze in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-11-2008, 01:16 PM
  4. Swapping VR L2 dash cluster with VS Stato L3 Cluster
    By wheredoesthisgo in forum Electrical Wiring / Questions
    Last Post: 07-04-2007, 03:28 PM
  5. Replace VN dash cluster with VX dash cluster
    By Xalies in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-02-2005, 06:55 PM
