Results 1 to 14 of 14
Thread: vl commodore missing under acceleration sometimes
    1996 commodore hsv VS Clubsport sedan
    Jul 2009
    Question vl commodore missing under acceleration sometimes
    Car was running fine , starts and idles fine but now and then misses when under accelation. Have changed leads but no difference. Can you help
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    spark plugs? ignition coil, fuel blockage change your fuel filter.
    oh yeah rev limiter is set at about 5500rpm. reach that under acceleration and she'll really miss.
    Nobody wants to play with me
    FAT.36L's Avatar
    FAT.36L is offline 8,000RPM FTW!!!
    Turbo S13 Onevia
    Sep 2008
    Maitland
    Its could be your TPS (Throttle postion sensor) my VL was dong the same thing and i found out that it was loose
    FAT.36L NOW RIDING IMPORT
    Full 5spd Conversion For Sale PM me
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    VL 86 Berlina
    May 2009
    Margaret River WA
    VT spac super6
    Nov 2008
    Riverton sa
    Quote Originally Posted by jatsvl View Post
    limiter is 6200rpm bud
    and it aint like a miss, more resembles hitting a wall
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    Jul 2009
    Jul 2009
    Thanks rb (goon) I have looked at those things ,changed distributor with new cas , replaced tps on engine, borrowed air flow metre off other vl but no difference ,replaced fuel pump and filter on outside of tank , new leads and plugs still haven't solved the problem
    Jul 2009
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Could be coil causing dramas man
    Vacuum leaks in intake piping and all vac lines.
    what about the intank inertia pump. i know the hose gets brittle and causes leaks and have a look at the filter on this pump as well
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    umm changed everything but the coil in the last 15mths, could be the transistor on the side of the dizzy too! GOOD LUCK with that.
    LOL! NATH did you see how old this thread is? you been drink'n agaaaaaiiin!
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Jul 2009
    Thank you to all who helped with my problem. The coil was the problem but only when under load we tested this by putting the car on a hoist and running her to 40kph while off the ground and with no load she was fine. Put her on the street and the surging was there. Thanks again brother inlaw and me very happy.!!!!
  1. VT V6 constantly missing under acceleration
    By BrentVR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-11-2010, 05:23 PM
  2. VS Commodore Missing PLEASE HELP
    By Frog201 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-12-2008, 10:57 PM
  3. engine missing under heavy acceleration
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 11-11-2008, 08:06 PM
  4. Commodore acceleration
    By saber in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-02-2006, 05:18 PM
  5. Commodore acceleration
    By saber in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-02-2006, 11:31 AM
