Results 1 to 7 of 7
Thread: Few Questions...
    VL 86 Berlina
    May 2009
    Margaret River WA
    Exclamation Few Questions...
    I bought this VL a while ago for 800 bux (unregistered). Shes a bit rough around the edges, but came with 17" rims, sub and amp, and had a bit of work done to the motor, and just planning on getting it over the pits then spraying it at work and selling it.
    Does anyone know where I can get a POD filter cover in W.A? If not over the net?
    And the car has no badges so not too sure what model it is, but has a tacho on the dash? Or can I tell from the VIN? Im pretty sure its a Berlina though.
    Does anyone know if I will have any troubles getting VL over the pits with 17s on her? And will 17s affect the speedo at all?
    And also the best oil to use, auto N/A RB30 with POD and extractors
    bf xr6 daily, vl project, wb ute project
    Aug 2008
    QLD
    If you really must run a pod then talk to Mace on here, he's got some enclosures for vb-vl pod filters.
    Check your plates to tell if it's a berlina or exec, and depend on how tired the engine is. 20w/50 is recommended but make sure it's a good quality oil and you shouldn't have any worries.
    Also if it's a berlina the door cards will give it away, they have different handles to the exec's and sl's.
    17's shouldn't worry your speedo too much, anything else?
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    Few Questions...
    Quote Originally Posted by kane88 View Post
    the door cards on a berlina are half fabric and half vinal
    where exec and sl are all vinal
    check the kick panels near your feet, berlina are coverd in fabric
    the door window frames will be black if a berlina, if same colour as car then its exec or sl
    tail lights (sedan) are slightly tinted by having the lines on the lense painted black
    berlina has sunglasses holder infront of shifter
    berlina has high rise centre console
    rear seat has a arm rest in the centre
    carpeted parcel shelf
    two reading light in the back on the roof
    electric antena - has a button next to the demister button
    there should be more then enough points to guide you
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    VL 86 Berlina
    May 2009
    Margaret River WA
    Just an executive then
    Has anyone had any troubles with hoses corroding out on there fuel tank? I just replaced the hole fuel system but hose next to internal pump corroded out. Went to wreckers yesterday and ripped fuel tank out of another VL, and it has the same problem, showed the wrecker and he said he'd fix it for me.
    VL 86 Berlina
    May 2009
    Margaret River WA
    And I dont have to run the POD, but it came with the car, and the wreckers down here doesnt have anything, and some young guy that buys it off me in the near future would probably like the look / sound. Im just trying to find a way to stop it sucking hot air..
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    Aug 2008
    QLD
    You might have dramas getting it registered with a pod filter that isn't shielded too.
  1. HQ Questions
    By speed_freak in forum V8 Development and Modification
    Last Post: 25-02-2006, 02:30 AM
  2. More VR Questions
    By jim468 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-02-2006, 10:29 AM
  3. 2 Questions...
    By VL2NV in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-02-2006, 07:02 PM
  4. few questions????????
    By zegerman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-12-2005, 05:40 PM
  5. 97 VT WGN Questions
    By gZ-VT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-08-2005, 11:50 AM
