tried to remove front springs from a vl, cannot get them out, undone everything possible, the suspension will not drop low enough for them to fall out. need help in a step to step basis just incase i missed something...
hey dunno if this helps but wen i changed mine i had to put the wheels on and put the car on the ground so it had pressure then the top bolt should undo.
Have you undone the lower ball joint and separated it from the bottom of the strut? You will need to undo the brake caliper and the tie rod end as well. The whole strut assembly has to come out of the car.
well, i just had another go at it and everything is definatly undone now except 1 thing at the bottom which the nut had a pin through it wateva that was and the nut is off and everything, it just wont separate, banged it with a hammer and it just sits there, maybe i'm not hitting it hard enough?
you should put the the strut top back in and put the three nuts back on so it is hanging then hit the sides of the ball joint mount until it pops,
don't undo that top nut until you have compressed the spring or you will do your self an injury.
Nobody wants to play with me
pretty sure that nut with the pin through it is a castellated lock nut on your steering arm.
When popping the balljoint out from the strut assembly (which is wat would be holding it in), I normally undo the nut enuf so when I bash the top it doesn't bur anything over. I also jack the brake rotor up to put more pressure on it releasing. Slog it a few times and normally they pop out.
I bought some proper ball join splitter tools.....but they were useless. I've gone back to using a big hammer.![]()
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
