Results 1 to 5 of 5
Thread: new pump 044 noisy and right fuel pressure?
    VL Turbo
    Apr 2009
    Default new pump 044 noisy and right fuel pressure?
    hey,
    finished my build and got it started the new fuel pump bosche 044 is really noisy its external, what can i do to reduce the noise.
    also got a turbosmart fpr800 rising reg and would like to know the right fuel pressure it should be sitting on at idle.
    any help apreciated!
    cheers
    VL 86 Berlina
    May 2009
    Margaret River WA
    vl berlina wagon 6cyl
    Jul 2005
    despite being mounted on a rubber isolated frame, all external pumps are still noisy, you get used to it
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    the 044 are known to be quite noisy
    i would say try wrapping it in a fibreglass blanket to try and block the sound but i might cause the pump to over heat a bit
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    VL Turbo
    Apr 2009
    cheers guys! ill get used to it! lol can any one suggest the right idle fuel pressure it should be on? after a high rev it almost cuts out then is ok. would that be because i have the intercooler on but not had a tune yet just using standard ecu or because i have removed stock reg and just using the rising fuel reg.
    thanks for the help!
  1. Oil Pressure Switch Disbaling Fuel Pump
    By Brin in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-12-2008, 01:49 PM
  2. genuine VN to VS high pressure external fuel pump
    By Boonz in forum Parts And Other Items For Sale
    Last Post: 10-05-2008, 01:46 PM
  3. Noisy Fuel pump VN Wagon
    By Disperse_daredevil in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2007, 06:03 PM
  4. VL Fuel pump pressure? any body know
    By customcaraudio in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-05-2006, 09:06 PM
  5. noisy fuel pump
    By kunifa in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-08-2005, 07:10 PM
