Results 1 to 7 of 7
Thread: Oil and water lines
    damankerrison09's Avatar
    damankerrison09 is offline Blue 87 VL
    5 Speed VL SL
    Feb 2009
    Default Oil and water lines
    I have a turbo setup for my VL and all i need is the turbo oil and water lines...
    Does anybody have any for sale and or can anyone tell me where to get some, or how to make some? Like can u just go to pirket or enzed and say can u give me oil or water line to this length with this fitting on the end..
    Thanks Daman
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    pirtek can make you the lines needed.
    Just tell them what length and what size banjo bolts using aswel as taking the turbo in to make sure all fittings clear
    I was quoted 300 for the lines.
    Just join ct and look. There always for sale there. I picked up all four lines for 100 posted.
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    5 Speed VL SL
    Feb 2009
    Oh wow thats more expensive than i thought, but ill look on CT..
    Also my mate just said i can have his old rb25 stock turbo, Can you tell me if it will work on an rb30?
    I dunno what size it is, so i cant tell you what it is actually called..
    Thanks Daman
    Oct 2005
    not exactly sure if it will bolt up on the stock manifold. Check the flange see if they mate up.
    Might also have to get a custom dump pipe as it may may not line up with the vl exhaust
    Also i think its a smaller turbo
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    Vk 5LTR
    Oct 2007
    Melbune
    dude *** pirtek just ring holden and get the part numbers for the oil and water lines then ring nissan and quote the part numbers and there can order them in takes about 1 week because there come from japan and works out cheaper then going to pirtek and atleast that way you have genuine turbo lines
    vy2 clubsport
    Feb 2008
    adelaide
    or try enzed.i used them to get oil fittings for my old turbo
  1. 304 Vac Lines
    By fu2 in forum V8 Development and Modification
    Last Post: 28-05-2009, 11:07 AM
  2. red lines
    By glowworm in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-05-2009, 01:29 PM
  3. Help lines
    By Lizzard in forum Jokes/Humour
    Last Post: 22-09-2008, 09:45 PM
  4. water disappearing - water pump - how to change?
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-07-2008, 01:30 AM
