Results 1 to 9 of 9
Thread: Help with VL drama :)
    VL commodore-1987
    Jul 2009
    Queensland
    Default Help with VL drama :)
    Hi
    Was hoping someone might be able to help... I have a VL commodore and one of the coolant hoses had a pinprick hole in it.. so it was replaced... then i dont know if this is coincidental but now when start the car first thing in the morning or when its cold it stalls straight away.. then after maybe about 3 goes it will stay going... it idles a little rough but not too bad... doesnt stall, and if its warmed up it starts straight away... its not blowing any smoke either. Is it maybe a failed oxygen sensor or failed airflow meter?? Any help would be much apprieciated.. Thanks
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    could be a vaccum leak on your air intake pipe. check the clamps are tighten..
    VL commodore-1987
    Jul 2009
    Queensland
    Thanks for your response.. We had already checked that, as our VL is notorious for it the clamps comming loose... so that isnt the problem this time.. thanks again
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    auxiliary idle air control valve.
    it's a valve that has a heater inside it and is bolted to the intake manifold runners.
    when it's cold, it SHOULD open, letting in extra air to bump up the idle for cold start (and cater for the cold start additional fuel).
    as the manifold (and heater inside the valve) warms up, it begins to close it. - when the engine is warm, it's supposed to be shut.
    My guess is that your valve is stuck shut, hence the poo cold idle and healthy warm idle.
    VL commodore-1987
    Jul 2009
    Queensland
    Thanks for replying..i will definately get someone to check that out.. thanks again
    Goon's Avatar
    Feb 2006
    GC. QLD
    Is it a manual or auto, if its manual make sure the big grey connection isnt connected near the tps.. thats for autos only..
    VT spac super6
    Nov 2008
    Riverton sa
    the big grey plug wouldn be there if it was a factory manual
    plus with the trans control computer removed it does nothing
    VL commodore-1987
    Jul 2009
    Queensland
    it's an auto.. sorry i probably should have mentioned that .. Thanks for all your suggestions
    Goon's Avatar
    Feb 2006
    GC. QLD
    take the afm ehile the cars running if it stalls its still good.
    do an ecu test, quick forum search in the vl area will help!
  1. Bit of a drama please help
    By 51cvq in forum LSx Development and Modification
    Last Post: 10-03-2009, 06:28 PM
  2. VK/VL dash drama..
    By nizmovk in forum Projects
    Last Post: 20-11-2006, 12:19 AM
  3. VN ute electrical drama
    By digisol in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-06-2006, 10:11 AM
  4. Engine Drama
    By CommodoreV-P in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-07-2005, 04:22 PM
