Results 1 to 20 of 20
Thread: vl earthing points
    vy2 clubsport
    Feb 2008
    adelaide
    Question vl earthing points
    hey guys i need to find out where the earthing points are on vl as my battery seems to be running flat quik.new battery i gt a feeling its running strate battery power.iam doing alternator this weekend but im 90% sure its not alternator as its been changed before hand
    v8commy is offline Banned
    vk calais 5.0
    Mar 2009
    reynella sa
    engine block any part of the chassis somewhere you can get a really tight earth and maybe clean where you put it so you dont get to much resistance maybe replace the earthing wire
    vy2 clubsport
    Feb 2008
    adelaide
    thanx but i need to know where it is?or do i follow it from some where in the wiring?
    vk calais 5.0
    Mar 2009
    reynella sa
    the earthing point is from the batt to the engine that earths the whole car from there all the rest of the earths are just off the car
    VT spac super6
    Nov 2008
    Riverton sa
    have you tried checking voltage while the car is running to make sure its not the alternator?
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    there is the main one attached to the rightside of the engine on the engine mount bracket, there is another one on the inside engine bay near the battery and from memory there is another in the boot near the wheel arch.
    also make sure the boot and glove box lights aren't stuck on.
    and parking a car on wet/ moist lawn over night will kill your battery too.
    Nobody wants to play with me
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    buy a digital mulitimeter bro theres one of the best tools u can get, easy way to find a suitable earth!!
    vy2 clubsport
    Feb 2008
    adelaide
    this is my problem
    vl flat battery problem
    hey all i have a problem with my vl[yes i ran a search and the threads i found didnt have the same symptons as my case]
    the battery seems to be going flat very very quik in my car.
    you will drive along then it will just cut out.lights and blinkers work still.put another battery in it and it will start.i then pulled the car out today from my side yard to do some work on it for an hr or so and yep again it was flat when i went to put it away.i couldnt try my second battery as it was flat so its on the charger now.i tryed to jump start it but it wouldnt start.also the other night the starter mtr jamed up as it wouldnt turn over like the battery was dead flat gave it a tap and it then fired up fine.
    what im thinking is the car is running of direct battery power if it cuts out when its running?could it be a starter mtr problem?should i check the earthing leads?if so where do i find them?
    also the battery has been re located to boot by previouse owner could something be wrong there?
    also when it goes flat it goes dead flat it wont evan try to crank over just turn key and nothing
    i had to push it away last night.i left that same battery in it last night got home from work today and it started 1st pop
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    with car running put multimeter on battery posts.. you should get reading of 14.2V from alternator. any less you power diodes are failing if getting 12 - 13V your alternator is knackered.
    like above make sure boot and glovebox lights are not staying on.....
    also if u have a stereo and have wired up the amps without the remote wire too head unit the amps will stay on and flatten the battery... check your remote lead. so the headunit turns off amps
    goodluck.....
    its nothing major
    vk calais 5.0
    Mar 2009
    reynella sa
    yeh i had the same prob turned out it was the head unit in my car was earthed under my dash so put it back to original earth it was fine but i dont drive it much so now the alarm takes the power and a while ago when i had the prob the first time i put one of those battery taps i got it from autobarn thats what i use now you just unscrew the tap and it cut the power if you look on my thread its got a pic of it good luck hope you find the problem
    vy2 clubsport
    Feb 2008
    adelaide
    not a stereo problem as it didnt have a stereo.and i have since installed a new head unit but its all done properly im not silly lol
    vk calais 5.0
    Mar 2009
    reynella sa
    vy2 clubsport
    Feb 2008
    adelaide
    ill hit it with a multi meter this weekend and replace some stuff see how i go
    vk calais 5.0
    Mar 2009
    reynella sa
    dont actually use the multi meter to hit anything youll probly break it theres money down the drain
  15. #15
    vy2 clubsport
    Feb 2008
    adelaide
    lol used a multi meter it ran 13 volts of batery,tested it again with lights on stil 13 volts,tested it again car on and lights on and still 13 volts.well that was before my motor shit itself.earthing points were fine.what should i look at doing once my new motor is back in september?i dont realy wana get it on the road and have this anoying elec problem.no it wasnt boot light or glove box either.
    would it be the alternator motor iodines?should i just get a reco alternator.it has a new starter motor in it already i thought it was statrter motor as it had oil on it from my catch can blowin oil out the filter over the starter motor but i realised it was happening before the motor let go
  16. #16
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
  17. #17
    vy2 clubsport
    Feb 2008
    adelaide
    yep i will get a new one of them also **** this cars running me broke but do it once do it right i guess cant ait to turn the boost up
  18. #18
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    nice man.... do u know somebody with a spare alt u can try??
    b4 getting one.
    or drop in to a auto elec and get him to check it quickly to be sure..(Not Fix it....he will charge you your arm)
    but your are getting low volts from it..soo its suspect...
    goodluck man let us know
  19. #19
    vl calais
    Sep 2009
    hi i also have a problem where the battery goes flat if the car sits overnight so i have to disconnect the battery all the time
  20. #20
    vy2 clubsport
    Feb 2008
    adelaide
    mine doesnt do it over night mine just did it at random times.but the next day it would fire
  1. Earthing points?
    By Brin in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-04-2009, 02:31 PM
  2. How many earthing points does the 5 litre have ???
    By undar8ed1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-02-2009, 07:05 PM
  3. Earthing Issue Maybe?
    By Sabbath' in forum Electrical Wiring / Questions
    Last Post: 07-07-2006, 06:32 PM
  4. 1996 VS Belina Earthing Points
    By Kevin in forum Electrical Wiring / Questions
    Last Post: 29-01-2005, 11:43 PM
