Results 1 to 17 of 17
Thread: Leaking coolant
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    Unhappy Leaking coolant
    Hey
    my old girl seems to be leaking coolant only after it has been driven, for example while it sits and doesnt get started it wont leak a drop
    but the other day i parkedit in the garage to work on the body and when i drove it out i noticed a puddle of fresh coolant and was wondering what the go was. i checked the level and it was only half full after i topped it up to full 1 week earlier hardly drove it
    i will get the car on the ramps soon and have a look under it but does anyone have ideas or had this happen before?
    cheers
    *also doesnt appear to leak if taken on a 25 minute drive or longer only if i start it and let it have a run for a bit in the garage
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    possibly welsh plugs leaking... as well as check all water hoses as well as heater hoses and clamps are all tight. radiator cap may be failing as well and check overflow is not leaking
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    did you bleed the system when you topped it up there maybe air pockets in there and idling the care will cause pressure to flow to the over flow tank then overflow to the ground, you should take note of where the puddle sits on the ground e.g under the radiator, left or right of centre.
    Nobody wants to play with me
    calais24/7's Avatar
    Jul 2009
    um no i didnt bleed the system before i topped it up. will get under the car on sunday and have a look for visible leaks i think its in the centre and pretty sure its not the radiator
    cheers for your replys
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    the bleeder screws are on top, id do it or ur head will go bang!!! make sure the clamps are tight..screw drivers dont do sht half the time. thats where the drill comes in!!
    calais24/7's Avatar
    Jul 2009
    mm ill have a look at the bleeder screws but is it neccasary if you are only topping up, also just got new gbox put in didnt this would effect it tho
    cheers
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    nope gear box wouldnt.... it depends how low it got.. i would bleed it.. bottom bolt first near thermo housing then top bolt on intake plenum do it and do it properly all air out or you will get air pockets and cause hot spots then it will crack.
    Goon's Avatar
    Feb 2006
    GC. QLD
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    try and use a copper washer for them.. makes a big difference when u gotta take em out again..
    i have had one snap on me i just drilled a small hole in it carefully and used a reverse thread screw
    easy outs work as well.
    calais24/7's Avatar
    Jul 2009
    found the problem
    my heater hose as had a blow out lol first it was a little gash then it got worse came back out to the car from the shops and there was a big trail of coolant coming from my car haha
    will have to get this fixed soon and you can hear the crunch when you moove the hose so it deffiantly needs replacing haha
    cheers and ill bleed it when i get a new hose.. it is just over half full, reckon i should still bleed it?
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    definitely bleed the system, always bleed the cooling system in the vl as the top water level is above the top of the radiator tank so if the radiator is low the engine is lower.
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    exactly the head is higher than the radiator so it will drain first.. thats the only design dilemma with the vl, but looks good..:P the skyline was quite level with radiator and head.
    calais24/7's Avatar
    Jul 2009
    ok so i got the hose off today with some help from a very good neihbour that knows his shit.. and lets say that thing was a prick to get off.. it was the hose that comes from the firewall to the main block.. theres two of them and it was the harder one:L
    it was such a bitch to get off
    but problem is all fixed now so this thread can be closed
    cheers espeicially nath83 & jatsvl
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
  15. #15
    calais24/7's Avatar
    Jul 2009
    yeh how is this for luck
    replaced the hoses after a few hours and a lot of swear words.. got the coolant all rady to go in , went to undo the bleeder screw on the plunum chamber and the c*** snapped clean in half, with the other bit in the plenum chamber thread. i slammed the bonnet kicked the wheel and stormed inside lol
    made a new thread with tap and die and drilled the other half of screw out and then the fan plastic protector thing was loose and the bottom would rub on the fan when driving (something we only noticed when we lent on it) so radiator came out and new bracket for the fan surround. then we bled the system now all is sweet as
    cheers again
  16. #16
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
  17. #17
    calais24/7's Avatar
    Jul 2009
    Haha yeh it originialy had a copper washer on it anyway.
    i might do what you do and undo it every now and then aswell
    cheers mate
  1. VS leaking coolant...
    By leelee in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-07-2009, 05:03 PM
  2. Coolant leaking from something...
    By LightningVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-11-2008, 12:59 AM
  3. leaking coolant
    By quiksilver1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-04-2008, 10:11 PM
  4. Leaking Coolant
    By Slow VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-05-2006, 08:49 PM
  5. Coolant Leaking Help Vn
    By WeBsTeR in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-01-2006, 08:18 PM
Tags for this Thread
