Results 1 to 7 of 7
Thread: Rear Demister Probs
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    Default Rear Demister Probs
    Gday Lads...
    slight problem with my rear demister.
    Im not getting power to the demister coil after putting a multimeter on one of the wires presuming one is the earth and the other is the supply not sure on Volts 12V maybe.???? yes i have tried both with a good earth im not getting any power
    When i press the button on my control on the dash the red light turns on and i hear a relay clicking over. All fuses are good, i cant find which one it is using.. Possibly it is sharing a fuse?? either the wire has been cut/disconnected under side trims... this causing it to blow a fuse i would guess if it earths out to body.( but all fuses are good as stated above) possibly it could be in the switch itself as in light is switching on but not switching over the circuit.???(unless it runs on same as the light)..
    So hopefully you fellas have got some suggestions, if i cant find it i will simply rewire in another switch to control it instead.
    Thanks guys in advance.
    Nath
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    VL Executive
    Feb 2009
    Craigmore SA
    im having similar problem, light comes on but doesnt seem to demist.
    havent checked any wires or anything though but i would also be interested to know how ya go
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    these are an absolute pr!ck of a thing, i have 2 lines that don't work but the rest do so I am not stuffing with it , I believe it is fuse #7, and I think your problem lies in the windscreen and rear window module( located, black box above bonnet release handle under dash), the rear demister is the V-violet wire at the module plug. and you are right one is supply(i think it is drivers side) the other goes to earth.
    it could be the switch they are not the best of quality, also if there is a hair line fracture in the copper tape on the window it will not work so look closely.
    hope I have enlightened you in some way, good luck
    Nobody wants to play with me
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    cheers but that good to know. ill have a look in the light when i have time. ill test the black box wire as mentioned to see if its out putting a voltage if im getting one here and not on the spade plug at the demister coil ill run a fresh wire in place.... hopefully i have not yanked it/damaged it installing stereo cables along the same run..
    Cheers Jats :P
    My old berlina had that as well 2 lines didnt work it was the bottom 2 they had a knife cut through them... possibly removing old tint film..
    VZ Exec MY06
    Oct 2009
    I had the same problem and just fixed it. At the rear screen there is a visible black wire on the passenger side which is earth; on the driver's side behind the plastic cover running down the C-pillar is a purple wire with a spade plug which is power. On mine the spade plug (with plastic cover) was jammed between the spade and the C-pillar instead of on the spade. It was tight so it would've felt connected if someone tried to plug it in without looking. I've only had the car for a week and it came from up north somewhere so it may have been like that out of the factory and the previous owner never needed it.
    The relay that operates the rear window demister is bottom RHS of fuse box, to find it just put your finger on it and turn the switch on and off and you can feel it switching. The switch will light up and the relay will activate with the fuse out so the fuse must be between the relay and the demister.
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    nice man ill have a look..
    if not ill just wire up an "aftermarket" toggle switch with LED and fuse it...
    thanks fellas
  1. Rear demister
    By Siggers86 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-06-2009, 07:52 PM
  2. Rear demister cause rear window to shatter?
    By gendi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-03-2009, 10:24 AM
  3. vn rear demister
    By grothie1978 in forum Electrical Wiring / Questions
    Last Post: 14-02-2008, 05:33 PM
  4. rear demister
    By VTPREDATOR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-01-2008, 09:12 AM
  5. Rear Demister Probs, HELP!
    By hotrod32 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-07-2006, 11:18 PM
