my mates giving me an ecotec and t5 box just wondering whats required to get it into the vl have read other posts similar to this one but didnt find them hugely helpful
cheers guys
I've driven fast cars I've done stupid shit in them each time i seem to come out on top i love you guardian angel
vp ss 3 months to go
will need a v6 k frame and engine mounts
custom exhust as its off twin headers
wiring
if using the T5 you will have to mix match things to get it working, ask VN_luke he has done it before
tailshaft
thats just a quick basics, anything more specific?
pritty simple really
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
will i be able to use the brakes from the vs in the vl? just for some added stopping power
you will need to use the brakes from a vs or better to pass engineering.
Vt brakes fit
can use vn-vs v8 brakes on front, same as VLT fronts
289mm think the disc are, single piston caliper
or look into vt set up, which use hub adaptors
298mm disc and twin spot calipers
but once you do the vt set up you can go even bigger by getting the caliper mounting brakets
which allow 330mm disc or even bigger with possible 4spot hsv calipers
but make sure if you upgrade you do the master cylinder and brake booster too help make the set up work to its best
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
just another question what do i need to do since the ecotec has the bcm does it require cutting into looms?
