Results 1 to 6 of 6
Thread: Air flow meter???
    damankerrison09's Avatar
    damankerrison09 is offline Blue 87 VL
    5 Speed VL SL
    Feb 2009
    Question Air flow meter???
    Just hooking up all my intercooler piping, and i need to know is it better to mount the AFM Before the turbo or after the intercooler somewhere?
    I was thinking if it was before the turbo, the air metered would be changed in density by the turbo, and then again when it pass's through the intercooler, so would that equal to 2 variants from turbo to throttle body?
    Not sure, I have no BOV as it is, but i should be getting one pretty soon (and no im not running a dose pipe just straight piece to pod to reduce flutter noise as much as possible)
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    as close as possible to the throttle in the cooler pipes is the best
    after the cooler - before throttle
    ive read many stories about people having it before the turbo and it would cause problems running and would stumble when taking off
    mine is under my RH rail in the cooler piping
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    VT spac super6
    Nov 2008
    Riverton sa
    5 Speed VL SL
    Feb 2009
    Yeh thats what i thought closer to the TV would be better! But then i read on some stupid forum that you cant run it after the turbo, but most VL turbo's with coolers do... Why does it stumble when its before the turbo? is it because the air isnt metered properly so the ECU puts in To much/ To little fuel?
    5 Speed VL SL
    Feb 2009
    Ok maybe not near the TV.. probably closer to my engine bay would help haha
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    stock turbo vl's have them in standard spot near airbox but i have seen them all over the place.. i would suggest after the Cooler i would say around the dizzy area where the piping is sweeping in over to Throttle body..
    thats where im gonna put mine...
    Or even better put this turbo in
  1. air flow meter
    By Matty o in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-03-2008, 01:27 PM
  2. Air Flow Meter Help
    By Statesman94 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-10-2005, 11:01 PM
  3. LS1 air flow meter
    By I LIKE COMMODORES in forum General
    Last Post: 01-09-2005, 02:43 PM
  4. Air flow meter...
    By stylen in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-06-2005, 02:03 PM
  5. vl air flow meter
    By psi berlina in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-06-2005, 09:07 PM
