Results 1 to 4 of 4
Thread: White smoke out exaust fix
    VH
    Sep 2008
    Default White smoke out exaust fix
    VL COMMY .Hi guys GOOD NEWS for those who need to know. I fixed my 'white smoke out the exhaust /disappearing auto fluid from slipping auto trans problem' it was the 'auto modulator /vacuum diaphram' got one from REPCO $69 bit expensive but anyhow its fixed.at first i thought the valve seals or head was stuffed,mechanic quoted $1000 to take head off and never said any thing about Modulator go figure! anyway to fix I just disconected vacuum hose and unscrewed old MODULATOR and screwed in new one ,about half a cup of auto fluid up vacuum tube to inlet manifold poured out onto floor!stuffed diapham! While i was at it i took the pan off the auto drained it and gave the pan a good clean before puting new fluid in the auto only lost the fluid that was in the pan about 1.5lt auto took about 3lt to top up .Now the engine and auto are perfect no smoke no slipping auto.So thanks to every one who helped on this Forum i saved a heap of bread and know how to fix this small but mysterious problem and feel bloody good about the acomplishment.cheers Donhomer
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    To defend mechanics, they don't over charge. They run a business, and are trying to make money. You are also paying for a professional service. Admittedly there are expensive mechanics out there, but it's all relative, if you can't afford the dearer one, find a cheap one. At one particular dealer over here they have a sign in their service department. It is a prestige european dealership, the sign says "If you have to ask how much it will cost to repair, you can't afford to drive it".
    Visit my Facebook page
    vl berlina wagon 6cyl
    Jul 2005
    I fixed the same problem of a split vacuum modulator diafram, with advice from this board
  1. vl turbo=white smoke
    By nasty1 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-08-2009, 08:45 PM
  2. v6 eco and superchared white smoke what does it mean??
    By genaero20 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-07-2009, 10:36 PM
  3. White smoke
    By ARROWS in forum VY Holden Commodore (2002 - 2004)
    Last Post: 10-11-2008, 02:43 PM
  4. White Smoke
    By New Supercharger in forum VY Holden Commodore (2002 - 2004)
    Last Post: 21-04-2007, 07:52 AM
  5. White smoke...
    By HoZy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-07-2006, 09:47 PM
