just wondering if anyone has fited a set of VT seats into a VL...front & back
cheers
Would be a huge stuff around for the back seat. Im sure fronts could be modded to fit the VL rails.
But the back seat would be a pain. Probebly easier to get the VT cloth and re-upolster the VL seats.
thanks Ozzie......I pointed out to me son tonight that the VN is wider than the VL (the VT seats r in my VN), so would need some major work on them....just thought it would be best to ask on here to confirm the problems....might end up with a set of VT seats ready for a VN for sale on here then...
No worries mate.
Yeah VT seats fit streight into VN-VS once the rails are changed and the loops on the back seat are cut.
VL's are definetly thinner and would require the actual foam to be cut.
hay just wunderen ya standard universal racing seats go in easy to a vs ute
i have vn calais front & rear seats in my vl the front went straight in but there was a little bit of modafication with the rears but was worth it looks unreal
front straight in rear hand to change the metal frame underneath the rear seat(vl frame into vn seat) unclip the cover and reshape the foam and more or less the same with the back support part very time consuming but like i said before very worth it
I just made up custom brackets for the vt rails, fitted perfect, put some seatcovers on and ya wouldnt tell the difference at an inspection, so much more comfortable and sit a hell of alot lower lol.
edit: not much room in the back seat now either.
