if the cas is gone should it bring up a code i had cas prob replaced it and drove it up the road and it died no spark
It should bring up the code yes..
does it have an injector pulse?
i got everything except spark
iv replaced coil and dizzi
In your other thread that i was talking to you in maybe the bearings are gone in that dizzy, i had a cas prob it was a pain in the arse
well iv replaced the dizzi and cas with a good workin 1 and nothin replaced coil but nothin im seriously over it lol any1 got a cheap workin turbo motor lol
if your positive you have a working and good cas and get a fault it would lead me too think the comp isnt getting the cas signal. Check the loom as harry has said in a thread bellow.
The cas tells the computer too produce injector pulse, spark and make the fuel pump run.
If its not sending a good signal you will have problems in all these areas
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
yeah true that 5speed good point mate
yer im gonna test the loom tonight spark is the only prob everything else is workin as for the turbo setup i might hold onto it and buy a top to bottom rebuild kit and get the turbo reco'd because the fins ahave startin to bend
ok sweet as man let us know how it goes
