Results 1 to 13 of 13
Thread: wont run
    vl calais turbo
    Sep 2009
    cairns
    Default wont run
    iv swaped motor an auto gearbox in me vl turbo an put a new moter an manual gearbox in but now the motor run like a billy goat bracks down an after about 15 miniuts it shuts down can any one help
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    vl calais turbo
    Sep 2009
    cairns
    yer it sort of runs off boost an if u try flattenen it it it splaters then like i say it shuts down an wont go as in wont start for about 15 min would the turbo timer have any thing to do with it if it was hooked up wrong
    Nackerz's Avatar
    Jul 2009
    yeah there is a possibilty the timer would have something to do with it
    Have u got another cas u could try might be that 2
    Jezza's Avatar
    Jezza is offline Ecotec Just Kicked In!
    VYII Acclaim
    Apr 2009
    South Australia
    it maybe a silly question but have you got a VL turbo computer hocked up instead of the n/a computer
    vl calais turbo
    Sep 2009
    cairns
    yer i got two turbo computers tryed them both still the same the so faults 14 23 an 31 tryed a afm fuel pump reg oxegen censore tryed deleten codes sprayed contact cleaner around
    Nackerz's Avatar
    Jul 2009
    vl calais turbo
    Sep 2009
    cairns
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    did u do the timing?? could be retarted.... and as detox-nath83 has said above id check....
    Goon's Avatar
    Feb 2006
    GC. QLD
    vl calais turbo
    Sep 2009
    cairns
    fixed problem must have been wiren changed wiren harness then leakey injector it ran a bit rough but when u powerd on it ran good so i changed injectors then it ran like shit again tryed various things witch didn't help checked oil an there was fuel in the oil could smell it changed oil an plugs problem fixed lucky was ready to burn it
    Nackerz's Avatar
    Jul 2009
    ro have fuel in the oil sounds like the rings are ****ed for fuel to get into the oil
  1. !!!i wont to hug the rim!!!
    By slappedvr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-08-2009, 11:02 AM
  2. help with a vn that wont run please
    By 078commyboy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-01-2008, 04:34 PM
  3. V6 wont rev...
    By 10000_fists in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-10-2007, 05:16 PM
  4. wont run
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-09-2007, 10:24 AM
