Results 1 to 14 of 14
Thread: original 5.0ltr hp?
    VL 5.0ltr
    Sep 2009
    brisbane
    Default original 5.0ltr hp?
    does anyone know the average hp for this motor?
    and some advice of what work i should do on her to make run abit better...
    cheers
    Attached Thumbnails Attached Thumbnails original 5.0ltr hp?-photo030-medium-.jpg
    VP Executive R-spec
    Jan 2005
    Find some old school tuning place that can "regraph" your dizzy will be the best/easy gain I'd expect
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    pfffwah - how long is a piece of string???
    I'd go a few steps forward on GF's advice - regraph the dizzy and take it to a carb specialist for a tune by somebody who knows how to tune the two making them work well together. They will probably want to know the cam and other specs to do the job properly.
    If you want to stick with the old style heads etc, find a set of B cast heads and HDT VL manifold + find a VK Group A grind cam. Do this before you do the dizzy/carb.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    Jezza's Avatar
    Jezza is offline Ecotec Just Kicked In!
    VYII Acclaim
    Apr 2009
    South Australia
    well this is what wikipedia says. 122 kilowatts (164 hp) with 323 newton metres (238 ft·lbf) but its probably down a bit from that because its been a few years since it came out
    VL Berlina
    Sep 2009
    West Auckland, NZ
    decent set of headers and freeflow exhaust, perhaps bigger carb, air filter, mild cam , and decent tune for starters should get the old girl back into life a bit.
    And the v8 lacked the power of the vl turbo, but when released was promoted for its towing capabilitys with the torque of the old 8!!
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    dont change the carb, it's the best performer and the most underrated.
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    Why oh why does everyone turn to Wikipedia? **** Wikipedia.
    Get it up on a dyno for a power run, it may not be 100% accurate, but will be a good guide / baseline on power gains for whatever mods you do for a comparison.
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
    vy2 clubsport
    Feb 2008
    adelaide
    set of efi heads and cam.extractors and exhaust.or rip it out drop an efi v8 in it
    burnz's Avatar
    2010 CRUZE Diesel
    Jun 2005
    springfield
    Quote Originally Posted by bow down View Post
    keep the carb job, you'll will be suppriessed how well a carb fed goes !!
    Powered By Garrett
    vy2 clubsport
    Feb 2008
    adelaide
    after how much you have to spend on it first?id go efi heads with cam/stall and exhaust personaly.if your after heads pm me i have a spare set
    burnz's Avatar
    2010 CRUZE Diesel
    Jun 2005
    springfield
    motor wise ?? less the $800 (baught from wreakers for $30~ old 308)
    deepend valve pockets by 1mm and a HLM320 cam sig earson ADV 6* thats it.
    plus deglase the bores new rings+new bearings+welsh plugs thats it
    used rochester carb as standard.
    Powered By Garrett
    vy2 clubsport
    Feb 2008
    adelaide
    burnz's Avatar
    2010 CRUZE Diesel
    Jun 2005
    springfield
    so a good 2k then
    i think were on different pages.
    inj motors then 2k at a minimum.
    carb motors well less than 2k.
    Powered By Garrett
    vy2 clubsport
    Feb 2008
    adelaide
    you would be up for boring/honing+decking and linishing crank.striping 2 heads down and reasemble.or at minimum at least hone the bores new rings and bearings etc.
    but i think hes just after some easy mods.so i still sey heads and cam all the way
  1. VZ 6.0ltr into WH
    By showtime in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-04-2009, 06:17 PM
  2. Vn Bt1 Rebuilt 5.0ltr
    By oyamum in forum Vehicles For Sale
    Last Post: 13-02-2008, 10:42 PM
  3. 5.0ltr differences?
    By Panama in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-02-2008, 06:16 PM
  4. VK BERLINA 5.0LTR 186,000K'S ORIGINAL (vic)
    By oyamum in forum Parts And Other Items For Sale
    Last Post: 02-07-2006, 10:16 AM
  5. interceptor 5.0ltr into vh sl/e
    By Spilly in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-03-2006, 09:08 PM
