Results 1 to 8 of 8
Thread: n/a VL no idle
    VS s1
    Sep 2009
    Default n/a VL no idle
    Heyas all, I'm new and I need some help lol.
    I'm just in AU for vacation again (come quite alot) and this time got myself a VL to drive around whilst im here. Problem is it doesnt idle. It runs and you have to step on the accelerator to keep it running. If you let it go it dies.
    I'm going to try to adjust the idle to something higher but was wondering if anyone could tell me where the screw is? Or should I be worried that this is something bigger than that?
    I'm in ACT at the moment if anyone is willing to help out Thanks in advance guys
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    on the ECU it has and idle adjust screw..
    or on the throttlebody just adjust slightly to open the throttle plate slightly.
    possibly Air flow meter is on its way out or Crank Angle sensor. as well as air leaks in intake piping
    Search is your friend for running issues as we have all coved this topic quite a bit:P
    Goodluck
    VS s1
    Sep 2009
    Yeah I tried searching but the first ones I found were just the running rough ones was thinking it might be mroe than just a screw.
    Thanks buddy
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    if u bring the revs up say about 900-1000 Rpm does it smooth out..
    i think idle is about 750Rpm factory set...
    if it smooths out i would say either leads/plugs.
    Clean or replace dizzy cup and rotor.
    clean trottlebody and intake runners.
    New fuel filter
    Air filter clean/ or replace
    No airleaks in intake piping.
    AAC valve and Fuel Reg working correctly/clean.
    VS s1
    Sep 2009
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    idle adjustment screw is on the back of the plenum chamber next to the AAC valve if you can't get the correct idle from there then adjust the screw on the ecu.
    Nobody wants to play with me
    VS s1
    Sep 2009
    A VR V6 bout to sell Yamaha Scorpio
    Jun 2009
    Whyalla SA 5608
    so put an idel in the car, dont leave it out
  1. 4k idle?!
    By markER717 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-08-2009, 12:47 AM
  2. ss ute idle?
    By vyjess in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-07-2009, 07:30 AM
  3. idle
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-12-2006, 04:10 PM
  4. vp ss bad idle
    By drewboy in forum General
    Last Post: 01-11-2005, 05:58 PM
  5. Very low idle on VN V6
    By HsvMan in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-09-2004, 05:56 PM
