Results 1 to 18 of 18
Thread: Few VL Questions
    Kirbs's Avatar
    Kirbs is offline L plater
    96 VS Executive S2
    Mar 2009
    Default Few VL Questions
    Ok, I'm looking at getting a VL. I want to turbo it but not just as of yet, But when I am ready I dont want to swap the motor out etc. I've heard about RB20's and RB30's, What one is it that the stock turbos use? I want something I can do a fair bit of work on by myself. As like a hobby/daily. Also, What are some other basic mods that can be done to them? I was thinking Extractors, 2.5" straight through, CAI/Pod, Maybe some slight engine work (crack tested, acid cleaned etc). Help would be appreciated. Please don't flame as I am just trying to learn. Thanks.
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    rb30 was turbo the 3 litre...............
    u basically have summed up the mods
    XF throttlebody in place of the stock 1 as well.(bigger throttle plate and housing)
    Dont POD it unless you have it boxed and fed with Cold air,,,(K&N panel filter instead of stock paper filter i would recommend)
    Pods only suck warm air from the engine bay so no enhancement there..only a nice intake sound :P
    Goodluck man. you will have years of enjoyment with the Vl.
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    rb30 came out in the vl they are stock unless you get a factory vl turbo they have an rb30 aswell but they have a A8 motor which is low compression
    these are the rb30's
    A8 motor = factory turbo low compression
    A6 motor = non turbo motor but has oil and water lines already tapped into the block High compression
    and the standard rb30 which dont have the oil and water lines tapped you have to tap the holes for the lines
    rb20's dont come out in the vl's and they are turbo motors but like the rb30's they have a factory turbo and non turbo
    rb20e non turbo
    rb20et turbo
    if i was to change the rb30 in a vl i would prob go for the rb26dett which is twin tubo thats what the t's stand for turbo
    Kirbs's Avatar
    96 VS Executive S2
    Mar 2009
    Ok, So if I buy a standard VL it will already have the RB30 and I can find a turbo to suit and slap it on there with no work? Do you have any links to useful sites etc? Cheers for the help mate. Thanks for backing up them mods detox. Will also be getting some wheels, paint and cleaning the interior up a bit as well.
    Cheers.
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    making sure u get an rb30 series 2 block which has the oil feed and drain as well as the water feed bungs tapped....
    under exhaust manifold.
    not too much work... making sure u have everthing.
    u can get the stock turbo setup... have a look around wreckers, trading post etc etc...
    it will be a high compression setup unless u put in a decompression plate.
    turbo injectors and ECU to suit unless u wanna run low low boost not maxing out N/A injectors.. 7psi i think can be run on N/A injectors/ECU untill u melt pistons from lack of fuel.
    which is equivilent to approx 10 psi Low compression setup.
    U want to run Intercooler etc to prevent pinging/detonation as well to keep the compressed air cooled from turbo...
    do a search bud heaps of conversions have been done...on rb30's
    i got all my gear to do it(well looking for intercooler piping to suit high-mount turbo manifold.)
    might just buy a few donunts in ally piping and weld one up myself.
    Kirbs's Avatar
    96 VS Executive S2
    Mar 2009
    I had a look in the quokka and there was an rb20det with the turbo for $1500. Does this sound about right? I wouldn't mind running the turbo at around 12 PSI. Would these engines hold up?
    Nackerz's Avatar
    Jul 2009
    i wouldnt if it was me as thats only a 2 litre an an rb30 is a 3litre just get an a6 rb30 or if you can get an a8 that be even better
    but if you get a a6 rb30 just put a decompression plate on it so you can run a higher boost
    with the right mods you can run 20psi if ya like
    vy2 clubsport
    Feb 2008
    adelaide
    Quote Originally Posted by VLWALKY View Post
    or do it rite and get some proper pistons and a acl head gasket or a cometic one.
    oh and walky they arent rb20et's they are rb20det's.
    the twin cam stuff is alot easier to get reliable power from to
    Holdfast is offline Donating Member
    VE & VL
    Jan 2005
    Kirbs's Avatar
    96 VS Executive S2
    Mar 2009
    Ok. I thought the 2 litres performed better than a 3L.
    Quote Originally Posted by bow down View Post
    What engine had the twin cams?
    Quote Originally Posted by Holdfast View Post
    Mate, here's some images and info on the series 2 block.
    Engine
    Thanks mate.
    Another question, These engines (rb30det) came out of skylines didn't they? I was looking in the Quokka and I only looked at the Australian parts section where there was only like 2 engines available.
    Cheers.
    vy2 clubsport
    Feb 2008
    adelaide
    rb 26 rb25 and rb20 are twin cam.
    rb30 are single over head cam
    and they arent rb30det they are rb30et the det part is just for twin cam et is for single.
    although you can put the 2.5 twin cam head on the rb30 and make a rb25/30det
    vy2 clubsport
    Feb 2008
    adelaide
    vl's came factory with rb30 nissans same as the r31 skyline
    the twim cam motors gets bang for bucks cheap easy power and reliability
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    rb20e non turbo
    rb20et turbo
    there was a rb20 vl from factory
    the vl imported to NZ was a rb20e (single cam)
    Austraila had the RB30e standerd and the turbo model was optional on the whole range (RB30et)
    not all are twin cams, the r32 had twin cam. the nz base had a single cam
    car is only as reliable as the builder and tune
    single cam or twin the only diffrence is the flow, which too me honustly isnt worth the all the money for so little gain
    the single cam has been proven to be able to work the big power
    the rb20det is said to be like a hyundai excel with a spark plug missing
    guttless till it hits boost but when it does its already redlining
    pointless and too small capcitay for a 6cyl motor, hence why a sr20 is so much better then it
    twin cam was on the RB20De/t
    rb25de/t and rb26dett
    no rb30 came with the twin cams all are hybrid with rb25 heads on the rb30 bottom end
    the rb30e was orignally from the r31 skyline, holden struck a deal with nissan too use it but
    holden designed the turbo set up for the rb30 and nissan never had the turbo set up for the rb30
    rb30 was also found in the GQ patrols in a carby and efi style set ups
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Kirbs's Avatar
    96 VS Executive S2
    Mar 2009
    Ok, So if I was aiming for maybe 185-190KW then what engine would be best?
  15. #15
    vy2 clubsport
    Feb 2008
    adelaide
  16. #16
    vy2 clubsport
    Feb 2008
    adelaide
  17. #17
    Oct 2005
    Quote Originally Posted by Kirbs View Post
    two safish ways too it but also depending on the engines condition orignally
    using a NA motor, with 10psi, cooler, 3" exhaust, factory turbo comp and injectors
    should see you in the area
    or a turbo motor with same parts but 15-16psi or so
    identically they are the same bottom end just one piston is domed to make higher compression (na)
    on a side note you dont want to go much past that power as the AFM hits its limits and then the computer just guess on the Air fuel ratio
    if it guesses wrong say good by too you pistons
    this can be fixed with a diffrent computer and a Z32 AFM but worry about that later when you want a little more power
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
  18. #18
    Kirbs's Avatar
    96 VS Executive S2
    Mar 2009
    Ok, I am pretty set on a RB25det. This engine has the twin cams? What are peoples thoughts? I might even try get 220-30KW a bit later aswell. Does this sound reasonable?
  1. SSZ questions
    By BANKS in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-04-2008, 03:09 PM
  2. Few questions
    By Ryan Mckd in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-04-2008, 01:47 PM
  3. 2 questions
    By Torquative in forum Car Audio
    Last Post: 23-01-2008, 11:58 PM
  4. VC Questions.
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-03-2006, 07:03 AM
  5. VZ SV8 questions
    By BLACKVZSV8 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 21-02-2006, 08:52 PM
