Results 1 to 13 of 13
Thread: Turbo project
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    Post Turbo project
    am looking at turning my daily vl into a turbo
    so basicaly whats a list of things i need and maybe some tips and tricks and shit coming from the guys that have done the conversion. i should be sweet though becuase person who will help me knows alot and has done it to a vl wagon. im yet to ask him :L
    was thinking it would cost around 1500?
    cheers
    Kirbs's Avatar
    Kirbs is offline L plater
    96 VS Executive S2
    Mar 2009
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Quote Originally Posted by vlcommodore01 View Post
    cheers
    I wouldnt go any hire then 2... if u want a cheap setup..and how much psi, the more u spend the more u get !!
    the vl forum has covered this a number of times.
    Quote Originally Posted by Kirbs View Post
    Would also love some info on what to do.
    Your on ur L's...
    Kirbs's Avatar
    96 VS Executive S2
    Mar 2009
    Quote Originally Posted by Goon View Post
    Your on ur L's...
    I'm from W.A
    VP Executive R-spec
    Jan 2005
    You just need the turbo top end and replace the tune on the na ecu with a turbo tune. Jobs done. If you don't have a later block you will need to drill and tap the block to get the oil line in and yes you should be able to complete it for 1500
    calais24/7's Avatar
    Jul 2009
    yeh true
    to lazy and to late at night haha
    was looking at maybe 10pound becuuase i herd some bloke got 190rwk off 10 pound?
    i no i only "heard" but yeh
    ill do a search and hopefully ill find what im looking for
    vy2 clubsport
    Feb 2008
    adelaide
    if your running a high comp motor on 10 psi i wouldnt go much thurther without a cooler.
    i made 195rwkw on 10 psi but its def no n/a converted slapped up thing.$1000 max for a turbo conversion these days you see whole motors for around $1500-$2000
    Spargo's Avatar
    Spargo is offline holden tech
    VT HSV Senator (SEN87A), VT V6, 90' Laser EFI.
    Aug 2009
    mid north
    VP Executive R-spec
    Jan 2005
    I was in a stock old NA motor on 20 psi the other day needed MUCH bigger injectors but it didn't blow up , VN luke took his worn out stock motor that he used to have before he built the good one to over 20 psi and made 280 rwkw with it no problems, couldn't break it (these are all WITH coolers)
    calais24/7's Avatar
    Jul 2009
    Quote Originally Posted by bow down View Post
    not quite shure what you mean
    i will be putting a cooler on?
    and it was just a gues to pay around 1500 for 10 pound?
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    as in intercooler so your charged/compressed air is cool when it gets in the cylinders helps aid pinging/detonation which causes damage to your engine
    Aug 2004
    $1500 is a fair price.
    cost me $1200 ish forrr
    3" exhaust, cooler 600x300
    dump,turbo factory lines, braided feed, turbo inlet turbo injectors, dose pipe airfilter and few other odds and sods. but im carefull where i spend money and did everything my self inc making cooler pipes etc.
    id guess around 150rwkw on 8psi was good fun, although blew up two autos.
    calais24/7's Avatar
    Jul 2009
    Quote Originally Posted by detox_nath83 View Post
    yeh i knew what a intercooler is but not to sure what bow down said lol
    cheers anyway mate
    i went to ct and all my questions where answered with the link above so cheers spargo
  1. Another vn v6 turbo project thread...
    By defa in forum V6 Development And Modification
    Last Post: 02-02-2010, 09:08 AM
  2. vr rb30 turbo project
    By tadpol88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-10-2009, 12:30 PM
  3. Project Turbo 6 (LPG)
    By redvk07 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-07-2008, 09:12 PM
  4. VR turbo project!
    By Fast_VR_Boy in forum V6 Development And Modification
    Last Post: 28-10-2007, 09:19 PM
  5. turbo project: beginning
    By PaRaDoX in forum V6 Development And Modification
    Last Post: 21-02-2007, 02:50 PM
Tags for this Thread
