Results 1 to 2 of 2
Thread: Timing belt & camshaft oil seal replacement
    VL Berlina
    Aug 2005
    Default Timing belt & camshaft oil seal replacement
    Can anyone please advise on the following:
    1. In the Gregory's manual it states that the rocker shaft retaining bolts should be loosened to allow correct tensioning of the new timing belt. I don't understand the logic, why?
    2. The camshaft oil seal was leaking, so decided to replace. The old seal was all perished so I need to remove the camshaft thrust plate to completely clean out the old seal and to replace the old O-ring. Is there any easy way to get the thrust plate off the camshaft ? It doesn't want to move without the camshaft.
    Thanks in advance.
    Graeme
    VL Berlina
    Aug 2005
    I've now answered my own questions, so will post in case anyone else is interested.
    The rocker shaft retaining bolts are loosened to relieve compression making it easier to tighten the "non-tensioner" side of the timing belt by turning the camshaft drive gear anti-clockwise, once the timing belt has been installed and tensioned.
    I didn't bother loosening the rocker shaft bolts but instead removed the spark plugs. Seemed to work out OK.
    The camshaft thrust plate can't be removed without partly withdrawing the camshaft. I didn't want all the extra work so perservered without removing thrust plate. For those who want to know, the thrust plate needs to be turned clockwise on the camshaft and then move it forward, to remove it. (Thats facing the front of the camshaft)
    Thats all folks
  1. Timing belt to Timing gear's ?????
    By MMH84D in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-08-2009, 11:28 PM
  2. Timing Cover Seal leak
    By diysv6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-07-2009, 02:29 PM
  3. front timing case seal
    By Galixia in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-12-2008, 10:22 AM
  4. F/S - ( Melb ) 308 / 253 hi-perf Camshaft/lifter/timing chain sets
    By GTS1963 in forum Parts And Other Items For Sale
    Last Post: 26-04-2008, 09:23 AM
  5. timing cover seal? how much
    By Fully in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-05-2006, 06:53 PM
Tags for this Thread
