Results 1 to 16 of 16
Thread: Budget Performance??
    =TUR7LE= Guest
    Default Budget Performance??
    HI guyz.... just wondering if u know of any budget preformance mods i can do 4 my vl?? stock as and needs sum ponies....nothing 2 rich tho...tight budget
    its a '86 auto
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    have a look through the forum mate. there are a number of other threads asking the same thing. youll get plenty of ideas and info from them.
    VL
    Jul 2005
    SA, Mount Gambier
    Go buy a POD filter and adapter from your local Autobarn. Then listen to that POD suck it in!
    =TUR7LE= Guest
    cheers guys...been thinking of building a motor...simular to the rb30/rb25 thread...it will have its diffrences tho...just smaller turbo, thinking maybe T03 high-flow...big port exsaught outlets big port inlets stuff like that....thinking maybe 26-66 cam's will b running a wolf ECU any other sugestions?? let me know...my buget has rapidly grown larger
    GMH-JC Guest
    vl5spd Guest
    i got a 5 speed vl with 2.5 inch exhuast and wondering if i put a pod filter and extractors on it would make much difference...needa beat my mates stock vn 5 speed.. help me out
    VL
    Jul 2005
    SA, Mount Gambier
    Quote Originally Posted by vl5spd
    I got extractors and a pod on mine, and i can say it certiny makes an increase in accerleration.
    s0sage's Avatar
    s0sage is offline Posting aimlessly ..
    MX6 - Turbo .... so flame me
    Mar 2005
    stock by stock 5spds, you'll be hard pressed to beat a vn..
    if your gates are in good nick, and your half decent driver and know your car well enough ... forget the clutch and dry shift it. if you can develop the skill enough, you'll save a heap of time over the your mate using a clutch.
    get the changes going at the right time so your revs dont drop so low your cars got no guts ... get a racing clutch fitted (mr-spares sells em on here for about $300 and i personally vouch for em) foot off the clutch and this thing GRABS!! dont even need to accelerate .. i was beating 900kg little jap buzz boxes left right and centre off the line with that clutch in my car.
    vl5spd Guest
    Wink
    arite thanks will get a pod and extractors..yer my mates vn goes pretty hard.. just a stock one tho..and my other mate has a k and n filter and a racing cluth in his and beats the stock vn i just wanna keep up with the stock cos he teases me down the freeway
    wkd Guest
    cheapest mod to get more performance.
    advance your timing.
    gives you a few extra kw and its free!
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    Yeah advance your timing, run on PULP, new plugs, leads and get some good cold air induction going.
    Make sure you keep your car serviced though, as a well serviced and maintained car is going to run alot better then some old crapbox. Not to mention you'll know that your car is in good condition.
    VL
    Jul 2005
    SA, Mount Gambier
    VS executive
    Jan 2005
    Quote Originally Posted by adox
    are there any downsides to advancing your timing?
    YO answer the mans question. i wanna knwo this too. sorry....please answer the mans question
    Half a carton and still going!!! Now thats Economy
    VL
    Jul 2005
    SA, Mount Gambier
    I thought advancing ur timing will cause the valves to not shut properly. That could become a problem if ya got piston slack???
  15. #15
    VL Crapbox
    May 2005
    The advancing of the timing i hope u are talking about is the distributer. All you are doing is telling it to fire when the piston is only 75% or so up rather than 80-85% (not accurate, just an example) and because premium fuel burns slower and cleaner, so the fuels power is felt for longer providing more power.
    If you advance the dizzy too much you will get detonation or pinging which is where the peak power of the flame is reached before it hits top and can burn a whole in your pistons in extreme conditions, not real smart. Sound is different in all cars, some it sounds like a rattle in the dash, others like theres a 12mm nut in the cylinder.
    Advancing the timinng belt one tooth is not something a novice should mess with. Thats different altogehter.
    Get the timing wrong with timing belts and if the clearance from piston to valve is too close, you can hit the valve with the piston or you will get a sound like the engine is firing in the air intake tube because the valve is open at the wrong time.
    If you want more inches, STROKE IT!
  16. #16
    VL
    Jul 2005
    SA, Mount Gambier
    Yeah, i thought we were talking bout advancing timing (as in timing belt) not the dizzy.
  1. budget headunit
    By reecey in forum Car Audio
    Last Post: 06-08-2010, 09:57 PM
  2. Budget Car Insurance
    By Tom_1569 in forum The Pub
    Last Post: 19-11-2007, 02:10 PM
  3. Lowering on a budget
    By Calais3800 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-09-2006, 02:51 PM
  4. Federal Budget
    By frenzal_tom in forum The Pub
    Last Post: 12-05-2006, 07:24 PM
  5. Budget Ideas.....
    By Macca177 in forum Car Audio
    Last Post: 11-09-2005, 12:31 PM
