Results 1 to 9 of 9
Thread: problems in inspecting the cam belt
    vl berlina wagon 6cyl
    Jul 2005
    Default problems in inspecting the cam belt
    since the engine will be seriously damaged if the cam belt breaks, I wonder why its so dificult to inspect it
    much needs to be removed to get the belt cover off, so that the belt, if not obviously near new, might as well be replaced with a new one at the same time
    the top part of cover can be partly pulled back but you cant see much, only the outside
    why isnt there a removable inspection port on the cover to allow a proper inspection of the belt?
    1990 VN Calais 5LTR.
    Oct 2009
    Canberra.
    Very true, I believe there is an aftermarket cover you can get that allows you the view it.
    Aug 2004
    the top cover has like 4 bolts... its pretty easy.
    also pretty sure the rb30 wont smash its self too bit if the belt breaks
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    4 bolts hold the top cover on, very easy too remove
    i believe the rb30 is a free spinning engine, the valve wont come in contact with the piston if the belt lets go
    but im willing to be corrected
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    86 VLCT/ 03 II VY SS Ute
    Aug 2007
    thats correct as far as im aware sean. and what do you mean inspect it ??? you can inspect it by taking the top cover off BUT just because it looks ok doesnt mean it is. ive changed lots of cam belts that are due if not over due and they still look fine. i have only ever changed 1 that had cracks and you could physically see it was way over due. I have changed 1 or 2 that have snapped and they also had no cracks just snapped, so keep that in mind
    at the end of the day in most situations the cam belt is recomended to be changed at 100,000 thousand Ks, best to just go by that
    VL Berlina
    Aug 2005
    if you remove the drive belts for the pwr steering, aircon, alternator & undo the 4 nuts holding the fan & fan pulley then you should have easy access to the bolts that hold both the upper and lower timing belt covers. This is not a major job, perhaps half hour if you have all the tools ready. To remove the pwr steering & alternator belts first loosen the belts by undoing the alt & p/s adjusting and pivot bolts. To remove the aircon belt, loosen the idler pulley nut and then lower the idler pulley by the adjusting stud on top of the housing directly behind it. Replace the belt if it has done anything like 100K. While you are at it check/replace the camshaft and crankshaft oil seals. Also check the welch plug for any sign of leakage.
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    top cover off is a 10min job as all above have said however it is useless because a visual inspection is no good, 100,000ks thereabouts is your best guide.
    the hardest part about doing the timing belt on the rb30 is removing the 26mm bolt holding the crank pulley on and then removing the crank pulley, if you don't have a rattlegun it just makes the job harder.
    Nobody wants to play with me
    Jul 2005
    Ive been told the RB 30 engine is interferrence type, can we clear this up, does anyone know for sure, obviously if it is freewheeling this reduces anxiety about snapping a belt
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    I know this isn't going to help much with RB30, but I know all the twin cam RB engines will snap/bend valves if cambelt goes.
    Gas, Ass or Grass nobody rides for free
    Quote Originally Posted by vsv8berlinawag View Post
    You tell him (coz you are right)
  1. vs v6 belt problems
    By ibt18u in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2009, 11:04 PM
  2. Fan Belt/Pully problems
    By kurupt99 in forum VE Holden Commodore (2006 - ?)
    Last Post: 10-05-2009, 07:39 PM
  3. Inspecting a VL
    By Unconnected in forum VL Holden Commodore (1986 - 1988)
    Last Post: 17-04-2009, 05:56 PM
  4. inspecting the cam belt
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-04-2006, 06:52 AM
  5. belt pulley problems
    By GeorgeB in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-07-2005, 03:36 PM
