hi there im from new zealand and if u dont know we have heaps of vls but bugger all turbo ones so i would like to turbo my vl the rb30et way not the way everyone else is (rb30det) over here so if some1 could please give me some advice about what to do and also apart from the obvious differences what is the differences between the na intake manifold and the turbo manifold and are the injectors top fed or side fed ? its hard over here as we only have very few factory turbo vls and no parts![]()
thanx phillipa![]()
From what I understand the turbo block has piston oil squirters and I think there is some difference in the auto trans if u r getting an auto... The auto trans from the Turbo model has no lock up converter and its internal workings are slighty different from what I understand.. I only found this out after I had my trans built and had an issue after the wrong (non-turbo) trans oil pump was installed...
I hope this is of some help to you...
Want more power for your rb30? Heres some answers!!
this link needs to be a sticky!!
try a seach mate. hopefull you will find what your looking for, try CT aswell as they are a little bigger![]()
